the pcb stops all failures...at least thats what they tell me and so far it works perfect.
New EKOS C1 Pre-Use Checklist
the packs get to about 120 degrees and start to shut down, the good news is thats about all the pack has left in it, cells are @ about 3.40v across the board.Comment
That is impossible.If my motor is pulling 120 amps continuous and the packs are 20c 5000 mah, they are only capable of 100 amps of continuous power, They WILL get hot, voltage will drop below lvc settings of the esc and that equals problems. How can a pcb on a battery stop my motor from pulling amps? How can it STOP heat?Comment
That is impossible.If my motor is pulling 120 amps continuous and the packs are 20c 5000 mah, they are only capable of 100 amps of continuous power, They WILL get hot, voltage will drop below lvc settings of the esc and that equals problems. How can a pcb on a battery stop my motor from pulling amps? How can it STOP heat?.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8sComment
a pcb can do what ever it is designed to do.
if you are pulling 120 amps you should not be using a 20c 5000 pack to start with.
once battery gets to any of the cut off points it shuts down...its that simple.
just like a pcb in a lvc stops voltage from geting to low.Comment
I've got 2-more
* As with any F.E. boat, stop and check your temps after a few minutes run-time. If any one or more components are too hot, stop immediately. Dont burn a hole in your hull!!
* Dont make any attempts to run 4s packs with the factory electronics. No matter what the venom videos show, or what venom claims. And if your motors still work after a few minutes on 3s, consider yourself lucky!!.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8sComment
I don't know why you guys have so much anger built up,can't someone that has nothing but good with this boat share it with others?Comment
I WISH I COULD AGREE WITH ALL THIS ................BUT
I HAVE HAD NOTHING BUT GREAT RESULTS FROM MY EKOS AND FROM
VENOM TECH SUPPORT
I HAVE BEEN RUNNING 4S 5000mah
SINCE DAY 1....8mins @ WFO NO PROBLEMS TO DATE...
CHECK THEAD TO SEE.
I WOULD LIKE TO ADD 1 MORE THING TO THE FE/EKOS CHECK LIST
AFTER EACH AND EVERY RUN,NO EXCEPTIONS,EVEN IF YOU JUST COME IN TO CHECK HEAT...SPARY WD-40 OR
SOME TYPE OF WATER SHED LUBE ON STINGER BEARINGS...DONT BE SHY WITH THE LUBE EITHER LAY IT ON.
and you should use grease on the bearings, WD does not lube like grease will.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8sComment
________
Buy Vapir VaporizerLast edited by FighterCat57; 02-14-2011, 11:15 PM.FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.Comment
BTW- I'm really glad to hear of your successes and am really looking forward to some video.
________
Chrysler sunbeam specificationsLast edited by FighterCat57; 02-14-2011, 11:15 PM.FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.Comment
