Traxxas spartan shimmies at full throttle
  • RotimusPrime
    • Mar 2017
    • 6
    My buddy bought a traxxas spartan and at full throttle the boat shimmies back and forth really fast. Why is this? How do I fix the problem?
    • 7990
    This is chine walk. It is caused by a deep vee mono running too far out of the water. Not enough hull is in the water for stability and any disruption can cause it to rock back and forth trying to balance on the sharp keel.
    It can can be solved either by running slower, or by lowering the hull deeper into the water, usually by raising the strut. Trim tab adjustment very seldom does much.
    • fweasel
      master of some
      • Jul 2016
      • 4309
      Raise the strut as much as the setup allows. You might be able to slot the mounting holes. There's a fair amount of play since the stuffing tube stops at the transom and only the flex cable exits. That, as Fluid mentioned, helps put more hull in the water. I ultimately tore out the original driveline in my old Spartan, filled in the hole, and drilled a new one 5/16" up from the keel and remounted all the hardware.
      The second thing you can do is driving style alone. Roll into the throttle on that boat easy, don't smash it down. That will help stop the chine walking from starting. Also, if it starts walking, you can add a little steering input to settle it down.
      Vac-U-Tug Jr (13mph)
      • Jesse J
        Former scale FE racer
        • Aug 2008
        • 7198
        Did this help? Was it the right amount?
        "Look good doin' it"
        See the fleet
        • fweasel
          master of some
          • Jul 2016
          • 4309
          the project hull I rebuilt with the higher mounted strut drove better. A friend used to have a stock Spartan and he was able to manage the walking with smooth throttle engagement, slight rudder input when it would start xandca sharp m445 prop.
          • Jesse J
            • Aug 2008
            • 7198
            Yep, had her out today and no shimmie, nor chine walk .. perfect height!
            Thanks Ryan!
            J
            See the fleet
