what prop should i get
  • paulfromtulsa
    • Nov 2013
    • 211
    hi guys i was wondering what prop i should get to get me the best top speed without ruining my electronics ? i am currently using a seaking 180 esc and leopard 1600kv on 6s.
  • Spartanator
    • 1060
    P215, what ambient temps do you run in? Maybe a X442. In fact, you could try a P220/X445 cut down to 42mm-ish...
    • paulfromtulsa
      • Nov 2013
      • 211
      I forgot to mention that I am currently using an x447 prop. Is there anything else that would be faster without compromising my electronics?
      • Pheyd
        • Sep 2014
        • 79
        Try an m545. Should give you higher top speed, but slightly slower out of the hole.
        • paulfromtulsa
          • Nov 2013
          • 211
          Thank you I will try the m545
          • paulfromtulsa
            • Nov 2013
            • 211
            I went to order the m545 and saw that they make a m645. What do you guys think of for the m645 instead of the 545 with my set up?
            • Make-a-Wake
              FE Rules!
              • 5554
              Stating the motor is a "Leopard" doesnt help us a whole lot Paul. What size is it 4074, 4082, 4092 etc........... The larger motors may be able to spin an x645. If its the 4074 I think the m545 is a good choice.
              • Spartanator
                • 1060
                I assume he is using the 4082. He states 1600kv, which the 4074 and 4092 don't have that "exact" kv. The Leo 4082 1600kv is what people usually out in this boat. I think having it try to spin a x645 it would result in torque roll on this boat. I might be wrong though, I never went past a P220...
                • paulfromtulsa
                  • Nov 2013
                  • 211
                  sorry guys yes im using the leopard 4082. do you think it can handle the m645? or do you think it will torque roll?
                  • Pheyd
                    • Sep 2014
                    • 79
                    gotta take baby steps to see if your esc/motor can handle it. You said you were running a x447 with no problems, correct? That being said, I wouldn't push the Spartan with a larger diameter prop. That means you are left with pitch adjustments.
                    The next logical step would be an m545 (smaller diameter, but larger pitch and the tongue removed. This should give you higher top speed but slightly slower acceleration out of the hole).
                    Other options would be the x642 (even smaller diameter but larger pitch), you could play with the m series, but i've heard lots of people having good balance with the x642 (motor and esc temps are great with good performance).
                    If you really want to push this boat, then the m645 is a good option (but I wouldn't make the jump directly from a x447).
                    • Make-a-Wake
                      FE Rules!
                      • 5554
                      Yeah, you dont want to go up any more in diamter with that thin light boat. An m545 or x545 seems to be in the zone to me.
                      • paulfromtulsa
                        • Nov 2013
                        • 211
                        I think I'm going to try to push the limits. I ordered a Prather 230. Will let you guys know the results
                        • Make-a-Wake
                          FE Rules!
                          • 5554
                          Wow, you really went big, the 230 has more total pitch than an x645...................... Hope it goes well, at least you have a 180a ESC, should cover it.
                          • Spartanator
                            • 1060
                            Maybe if you don't like it you could get it cut down...
