Throttle Control
  • Tripper
    • May 2014
    • 2
    Throttle Control
    Hey Guys.I have a question.Who is using the TQi at 50/50 and who at 70/30....What is the advantage or disadvantage of both
  • Spartanator
    • 1060
    70/30 you get more forward throttle room with less reverse room. 50/50 I run at that, not by choice but it works for me. If you run at 70/30 I would keep it that way... I just don't know how to change mine back, I am not very motivated to do it. "Don't touch it if it ain't broke" lol
    • PowerDemon
      • 351
      I run 70/30 just because I like the longer travel of the trigger. You will need to reprogram the ESC to switch back and forth between both settings.
      • Tripper
        • May 2014
        • 2
        Thanks guys I no how to change the end points on the castle esc.Just wondering what everyone is using and why
        • Spartanator
          • 1060
          The 50/50 is used in the land based rc's from TRX, I may figure out out to change mine.
          • PowerDemon
            • 351
            In the Spartan manual pg 15 under "Setup Programming (Calibrating your ESC and Transmitter)" Is what you need to do to your ESC to change the throttle setting.
