Traxxas Spartan upgrade recommendations needed please!!
  • Mike090376
    • Feb 2014
    • 3
    Hello all, I am new to this forum. I have read a lot of different threads on here regarding upgrading a Traxxas Spartan and would like your input on the following:
    I just purchased a Spartan and would like to upgrade whatever is needed to get 60+ MPH out of the boat. I am lost when it comes to kv ratings on the different motors. I have seen that a Leopard 4082 1600kv with a Seaking 180a esc is a good combo. Will this set up hit 60mph? I am sure I will need a different prop and flex cable, suggestions on that are appreciated as well.
    I currently have an MG 29 and a Blackjack 29. Wanted to change it up a bit and get a v hull but I all want to make this boat a screamer.
    Thanks in advance for any input you can give me.
    Mike
  • martin
    • 2887
    Theirs a dedicated Traxxas section further down the page, you will get more experienced answers from those that have modded their Spartans their.
    • Jeff Wohlt
      • Jan 2008
      • 2716
      Put in a brazed cable like I make and run 6S. Should be good but tweaking to get 60 will be about your prop and length of run time you want. If you really want to cook it up grab a Castle Motor closer to 2000 KV and run 6S. They can handle it.
      www.rcraceboat.com
      [email protected]
      • lenny
        • Sep 2010
        • 4293
        Hi,
        This guy went nuts trying to get that boat to handle and run at high speeds.
        There is lots of good info and video's hear.
        http://forums.offshoreelectrics.com/...on-the-Spartan
        And also what can happen in a second to the hull.
        http://forums.offshoreelectrics.com/...l-thanks-again!
        ? ONLY IF THEY WORK
