Information on traxxas spartan
  • Russell
    • May 2013
    • 3
    I am new to r/c boating and recently bought the spartan with the castle motor and esc. So far the boat has been a lot of fun. Running it on 3s 6400 and it does well. Do I really need to upgrade the cooling system to dual line as most everything I read says to. It doesn't really heat up at all so far. I have also noticed water in the hull. Is that from the cooling jacket on the motor, or is it from reversing too much, or is it normal ? Any information would be helpful. How far do I need to upgrade to make this a reliable boat?
  • Mulisha
    • Apr 2013
    • 241
    You running it on 2x3s 6400 i assume? The stock water jacket expands at high speed due to the water pressure that will most likely be where the water is coming from, i would definently upgrade the jacket OSE has some and even HK has some not sure on quality. If your temps are fine i wouldn't upgrade to dual but if you start changing props it might be wise. How often are you reversing i would avoid that as you much as you can. If you stick with stock maybe just change to metal prop with same pitch and diameter i dont think you should need to do any upgrades. I have a spartan and only upgrade are 42x1.4 cnc prop, alloy jacket, trim tab adjusters runs 90km/h.
    What's life if you ain't having fun
    • Russell
      • May 2013
      • 3
      Great thanks for the info. How much did your metal prop change performance? Do you really need to get them sharpened and balanced once you buy them?
      • Mulisha
        • Apr 2013
        • 241
        Got about 12-14km/h increase just from prop. It's cnc which is meant to be "precise" and balanced/sharpened. If you don't buy cnc props then yes you will have to sharpen balance, even some cnc won't be perfect.
        • Speedracer128
          • Apr 2013
          • 288
          Mulisha,
          Did you that speed difference by using a GPS?
          • Mulisha
            • Apr 2013
            • 241
            Yes want to see if it really did the speeds they claimed when stock. Then tested again with the new prop
            • Russell
              • May 2013
              • 3
              I am having issues with the reciever. It got wet A few times but after drying it out it would be green light and go. Now it just blinks red and will not work. Lights on the esc are green and I have tried to bind it thinking it would help but no. Any suggestions??
              • Speedracer128
                • Apr 2013
                • 288
                Sounds like it it's bound
                • lenny
                  • Sep 2010
                  • 4294
                  Are the cells good in your tx ?
                  Check them and than try to bind it again.
                  Also water will come up the stuffing tube of your flex shaft,
                  Make sure you grease it good after a day of running.
                  You can also make a water line seal for the stuffing tube to the flex shaft,
                  To help stop the water and grease coming out of it.
                  ? ONLY IF THEY WORK
                  • Derek12v
                    • Apr 2013
                    • 3
                    Make sure you are turning the transmitter on before you connect the batteries to the ESC. I don't know why but the receiver doesn't recognize the transmitter sometimes if it's not on before connecting the batteries. I would go ahead and change the batteries in the transmitter as cheap insurance.
