Ok, something is definitely wrong here, at least, I think.
I'm running a bone stock Castle Spartan w/dual pickup rudder, and aluminum cooling jacket. I took my sexy new pair of 2s 12,800mah 40c lipos for a test run, and everything was going very well for about 10-15mins, but then I thermal. She was smooth, stable, going about 35mph, running WoT almost the whole time. I had a couple of spin outs, but that's it. Water was smooth. The cooling lines were open and flowing. I had a little more than a 1/8" gap between the strut and dog.
I had just regreased the shaft and lubed the motor/strut prior to this run. I always place my batteries all of the way up front for maximum stability. I brought her in after the thermal, and everything was pretty hot. No smoke/fire, but warm. The motor was hot, ESC was hot, lipos were both warm, wires were warm, Traxxas connectors were hot. The wires and connectors got so hot that they started to melt thru my swim noodles! Lol!
So, what the heck?
1. I shouldn't be overheating on 4s on my setup, right?
2. I think my flex shaft might be rapidly losing grease because I notice it's pretty dry after each run. I think that might be causing the overheat? Should I try removing the teflon liner?
3. What's the best way to keep grease on the shaft?
4. The overheating is probably not due to my larger than average batteries/run times or my full forward battery placement, correct?
5. Would a wire drive run cooler? Can you be hard on the throttle with wire drives and not worry about breaking them?
Thx in advance for all responses!
