what if I take off outer trim tabs and move them in on spots closer to strut and just have the inner ones??
Find The Mounting Holes For Second Trim Tabs
You should add the additional set of inner trim tabs to help stabilize and minimize chine walk at higher speeds, 45 + mph. Alot depends on where you place your batteries and the weight of the batteries you are using.
Start with the trim tabs level with the bottom of the boat and move (bend) the inner ones first. There is alot of trial and error here.
Maybe to help, chine walk occurs when there is very little of the boat in the water and it is running on a very small portion of the hull. Once the boat gets byond this it will fall to one side and then bounces to the other side, hence chine walking.
You may also try to accelerate slower, make sure there is no play or slop in the rudder and the strut.
The causes of chine walk are many and the cures are few.Comment
If you are using the outer tabs only you will not need to adjust thoes as they are most likely not in the water when your boat begins to chine walk.
The inner tabs, once you have them installed, should be left in the neutral position and if needed adjust down.Comment
When i did it on my Spartan i did it with a pointed small screwdriver and just rotated it into the hull untill i had a hole big enough to take the screw, i then just screwed the screw and it finds the hidden threads inside and screws in, i then just had to line up the trim tab and do the same for the second hole. This task is dead easy believe me i was amazed how easy it was.The Spartan must have been molded for a second set of trim tabs to be added when made.Comment
3. Use a sharp awl to puncture, or carefully drill out, the center of the "donut" through the hull to open access to the molded bolt recesses.*!**NOTE:*!**Be careful not to drill deep.Last edited by thebomber; 06-20-2012, 08:58 PM.Comment
The plastic is often galled into the threads on the bolts from factory installation without using some type of thread lubricant.
It can be very difficult to remove the screws, AND, there is a risk of stripping the threads out of the plastic if badly galled.
After removal, clean all the plastic out of the threads and then lubricate before re-installation. It is preferable to use a non-petroleum based lube. 100% synthetic, bees wax, or even vegetable oil. Petroleum based lubricants may dry and crack the plastic over time.
KevinComment
I use both, but the factory installed bolts are often too tight for my Allen bit in the driver. It is a round shaft,not hex, and often slips in the chuck when trying to do the initial extraction.
Once they are out, and I have had a chance to lubricate them, they run in and out nicely with the driver.
I have had a couple that were so tight they stripped out the Allen head, and have required backing them out 1/4 or 1/2 turn at a time with a vise grip..
KevinComment
I have had a couple that were so tight they stripped out the Allen head, and have required backing them out 1/4 or 1/2 turn at a time with a vise grip. Unfortunately when they are this tough to get out, the threads in the plastic are usually too far gone to reuse the original bolt.
KevinComment
