My Castle System Spartan on 5s 2 packs parallel 5.0's
  • Zx14187
    • Sep 2011
    • 29
    My upgraded Castle System showed up today, aside from a piss poor solder job by traxxas on the esc and the esc water intake pipe having to be tweaked the test run was great!
    My Spartan it stock except the parallel connector and the dual pickup rudder with second water discharge fitting (one on each side).
    With 2 Turnigy 5.0 5s packs in parallel my run times are very long, did not run them down yet but after 15min of mixed speeds the lipo alarms were showing 3.75v in each cell. Im new to lipo but I've found that running these battery's to 3.4v cutoff under load takes about 4400mah to full charge.
    Everything stays very cool, the motor and esc were Luke warm after 15 min of mixed speeds with several high speed passes. The packs were cool as can be.
    As for the speed, it was plenty fast! Much faster than I thought it would be, I'll stick my cell phone in there with gps running tomorrow for a measured top speed, I did have a little side to side rocking at full power, but sliding the packs forward an inch stoped it for the most part, most of the top speed runs were true and straight, but if you hit a wave just right it starts rocking side to side a bit (the packs are about in the middle right now). I don't see any need for 6s in this boat for the average Joe, it is very fun on 5s and runs cool to the touch! No more Nuclear Meltdowns!
  • marksp
    • Aug 2011
    • 15
    Thanks for sharing! I haven't run my boat yet and was planning on running a couple of 3S in series, but now based on your experience will order up a couple of 5S packs and re-wire in parallel.
    BTW, what's the C rating on those packs?
    • Zx14187
      • Sep 2011
      • 29
      They are the 30-40c 5.0's (hobby king) they took a few cycles to really wake up.
      I adjusted the strut up 1mm and tested it today, all seemed great! I could hold full power as long as I wanted, it did dolphin dive into a big wave, but after a few seconds it floated back up and took off again. Run tines are 30min on choppy water.
      • dag-nabit
        • Feb 2011
        • 775
        I only got a few runs in on 5S before deciding to shut it down for the season, But I agree, the Spartan runs nice on a 5S setup, and reduces the chances of cooking the electrics.
        I did find moving the heavy 5S batteries ahead for increased stability did affect the top end speed a fair bit, so I'll be interested to see what your results are on the GPS.
        Kevin
        BTW I was running my 5S batteries about the same place you are, center to slightly ahead of center, for good stability.
        • Zx14187
          • Sep 2011
          • 29
          I did try to get a speed reading with my iphone, but there is no signal in the area.
          It's fast enough to have to worry about it taking flight in choppy water and or submarining into a small waves lol. I thought I'd lost it yesterday after a full speed run went wrong and it darted into a wave, it was out of sight for several seconds! I have several vids showing full speed, I will post them up soon.
