The new castle esc is on its way back to traxxas
  • busaboy1441
    • Jul 2011
    • 16
    It just went out right in the middle of the lake no power didnt smoke or anything wasnt even in the water for 1 minute so i dont know they want it back i was running 3s 5000mah 40c packs stock prop grease the shaft after ever 3 sets of lipos so anyone wanna buy a really nice castle esc in about a week new lol
  • Savage Skidoo
    • May 2011
    • 332
    They gave me the 2nd version . what you said above in your post happend to me on Sunday . I mailed it back . 3 motors and 4 esc's WTF CRAPXXAS .
    www.facebook.com/Boaters and Crawlers Durham
    Durham Off Road Rc Club - www.dorc.ca founding member
    • busaboy1441
      • Jul 2011
      • 16
      I know this sucks i am on my 4th set of esc and motor i mean they keep replacing them but damn i just wanna run my boat i am ready to send the boat back and tell them to keep it till they get it right lol
      • 1truckerdan
        • Aug 2011
        • 329
        If you have burnt up 4 on the same boat .....then there might be a problem with the setup you are running..... prop? batteries? Something binding?
        Daniel
        When you know it all.......you never will learn anything new
        • busaboy1441
          • Jul 2011
          • 16
          i dont think so i think they are using cheap parts i mean i am running stock prop i temp everything so i dont know this is the first castle setup i had to send back all the others were the stock esc and motor which i know were junk i think the problem is that you have a 1800kv motor on a 6s setup and it is drawing to many amps they need to put a bigger esc in the boat from what i see no one runs 6s on a 1800kv maybe 1500kv or 1600kv like the original motor but they bumped it up to 1800kv so who knows when they are going to get it right
          • 1truckerdan
            • Aug 2011
            • 329
            The replacement motors are made by CC in their plant in China just for Traxxas...not by traxxas and the esc is also made by CC...not by Traxxas.
            CC is having less than a 3% failure rate with these....you are at 100%. Something is going on that is causing 4 of them to fail.
            All I am saying is check it all out before you try again.
            Daniel
            • busaboy1441
              • Jul 2011
              • 16
              This is the first castle setup i have sent back all the others were not castle i understand they are suppose to be better but i dont think they are i hope they get it right i must be in the 3% because castle didnt make the other esc and motors in the first batch of boats and they kept sending out the same old junk you would run a set of lipos threw it and it would be 160 deg F you let the motor set and went to 180 lol they were trying to get out as cheep as possible but hey to each there own thanks for the info genius
              • 1truckerdan
                • Aug 2011
                • 329
                I was just tring to help.
                Me,I rely on my math, feedback about other peoples success,and failures.....and a temp gun.
                I have had failures also, and most of them were because I pushed my electronics too far. I now try to keep it below 80% of what the limit of it is.
                Just my 2cents
                Daniel
                • busaboy1441
                  • Jul 2011
                  • 16
                  Well thanks for trying to help its frustrating just want a boat that will run on 6s lipo and run 50 mph just as they advertised
                  • dag-nabit
                    • Feb 2011
                    • 775
                    I hope this is not an indication of what is to come with the new electronics. I questioned the sensibility of the decision to increase the motor to 1800kv but hoped Castle knew what they were doing.
                    It would be nice if Castle, or Traxxas, would release information on the AMP rating and other details in the new ESC, that would help determine what to expect from the new setup.
                    I torched a 180 amp ESC running 2000kv on 6S. If the new Castle ESC is still rated around 80 amps like the original, or even increased to 100 - 120 amps, it is still under rated for an 1800kv motor on 6S in this boat, and the problems may well continue.
                    As for 3% a failure rate, the new components haven't been on the water long enough to determine any valid success/failure record, so those types of numbers are really meaningless at this point.
                    I hope the two or three reported failures so far are just flukes, but, I admit, personally I don't have a lot of confidence in the decision to up the kv rating on the motor. I sure would like to see some specs on the new ESC.
                    Kevin
                    • martin
                      • 2887
                      40,000 rpm unloaded on a rtr mono hull of this size is simply asking for trouble, Youd of thought they would have learnt a lesson the first time around. But they clearly didnt, Still what do boaters on this forum know. Oh yeah their the ones that soon got this boat running mid 60s mph & reliably as well.
                      • JPriami
                        N4FOX
                        • 1675
                        Are the new motors the same size cans as the old ones?
                        Also are they still 2 pole or 4 poles now?
                        • 1truckerdan
                          • Aug 2011
                          • 329
                          Here you go...
                          07.21.2011, 11:33 PM
                          Oh, and if you want some details:
                          The new Traxxas ESC uses the latest MOSFET from Infineon -- a really kick-butt ultra-low RDSOn part. Expensive, but worth it!
                          It's a large footprint to keep everything nice and cool. Comes with a 5A switching BEC built-in, and integrated 5.5mm bullets to flow power smoothly.
                          It's fully epoxy encapsulated, using a very low viscosity epoxy applied by some new robots that Castle built for our in-house potting line.
                          The motor is a four pole, 1420, 1800kV motor based on the design of our popular 1410 SCT motor. It uses stainless hardware and bearings to (hopefully!) keep the rust to a minimum. Still need to oil the bearings occasionally as the lube can get washed out with water splashing. We were originally planning to use sealed bearings, but they didn't last as long as the shielded bearings -- so we stuck with standard shielded bearings.
                          Of course, Traxxas got a nice, cool blue finish on the motor, and a clear anodize on the end-bells. The laser etch looks very nice with the clear anodize.
                          Patrick del Castillo
                          President, Principle Engineer
                          Castle Creations
                          • dag-nabit
                            • Feb 2011
                            • 775
                            Thanks 1truckerdan. I had seen that information before. I would really like to know the amp and voltage rating on the new ESC.
                            I had seen it posted somewhere, Tower Hobbies I think maybe, that the new ESC is designed to handle more voltage and power, but the question remains, how much more.
                            I also checked the Traxxas website again today, all the product info, and the online manual for the Spartan, is still for the old model.
                            Kevin
                            • JPriami
                              N4FOX
                              • 1675
                              I'm still missing the size of the motor. Like diameter and length.
