spartan-steering issue
  • vfrman40
    • Feb 2010
    • 9
    have had a few spartan boats and they wont steer at all---check the trims and end point and also reset the radio---they rudder steers only like maybe 5 degrees--also tried a new servo and same thing---i go desperate that i put in a aftermarket servo saver to at least get like 10-15 degress turn radius--anyone else having issues.
  • dag-nabit
    • Feb 2011
    • 775
    No problems with steering. Both our Spartans turn well on stock servo. Not sure what you are using for a tx but check to see if the steering sensitivity (travel points) has been reduced in the tx programming.
    Kevin
    • rinski73
      alien life form
      • 58
      sounds like a dual rate setting problem
      IF IT DON'T GO FAST WHY HAVE IT
      • vfrman40
        • Feb 2010
        • 9
        steering spartan
        i checked steering sensitivites and dual rates everything and stock radio....thats why im at my wits end
        • dag-nabit
          • Feb 2011
          • 775
          A quick re-read of your original post and I see you have already tried most of the usual suspects. And you say you have had more than one Spartan doing the same thing?
          I was going to suggest trying a different receiver, but if you have had this same problem on more than one boat, it is unlikely that will help.
          When you say 5* turn radius, do you mean the rudder only moves 5* left or right of center, or do you mean when you are running the actual turn radius of the boat is only about 5*?
          My Spartans do not turn nearly as well at very low speeds as they do at higher speeds. At high speeds it is easy to over steer.
          Kevin
          • vfrman40
            • Feb 2010
            • 9
            spartan - steering
            i mean 5 degress left or right for center rudder....like i said im stompped and dont knwo what to do for my customers.
            • dag-nabit
              • Feb 2011
              • 775
              I will try and check mine out this weekend, maybe take a quick video to help you determine if you are seeing the same movement the rest of us are.
              Kevin
