Wire drive question....
  • Rcforever27
    • 240
    Should i run the traxxas Teflon liner with a wire drive? I have a .187 flex drive on my other Spartan , and I'm not running one i'n that.... But i wasn't sure if i should with a wire drive setup... Thanks i'n advance....
    Scott Spartan#1: castle hydra ice 240 castle 2200 Prather 220 turnigy 5.0 45c lipos with max amps water pump... Spartan#2: leopard 1800, octura 440 ,traxxas 8400 mah 25c lipos.....updated deeper hull....
  • Jeff Wohlt
    • Jan 2008
    • 2716
    Sure...use the stock liner...it has plenty of room but will keep the wire a bit cooler and quiet.
    www.rcraceboat.com
    [email protected]
    • Rcforever27
      • 240
      Ok thanks...
      • mtnbiker94
        • May 2011
        • 62
        Yup, I just got my wire drive from Jeff the other day and I run it with the stock liner, I put 2 runs on it and after the second one I pulled it out, and there was still some grease left, and it wasn't all black and nasty like on the stock one.
        • Jeff Wohlt
          • Jan 2008
          • 2716
          I like to sand the wire with some 320 and then use some metal polish on them...very smooth and resists rust much better
          www.rcraceboat.com
          [email protected]
          • Rcforever27
            • 240
            Sounds good I'll have to try that ... Still waiting for my bare hull to come off backorder.... This waiting is killing me.... I guess I'll just run my other Spartan for now while i wait lol... Thanks again!
            • ebomb
              • Jun 2008
              • 5
              just came back from being at my lake house for a week. probably burned through6 packs on 6s checked the wire drive and still had the marine grease all over it. from what ive seen and read this is a must have, very nice job jeff!!
              • LarrysDrifter
                Big Booty Daddy
                • May 2010
                • 3278
                Wire drives are definitely nice if you're able to use them.
                • Jeff Wohlt
                  • Jan 2008
                  • 2716
                  glad to hear it ebomb. they work in about anything if built right
                  www.rcraceboat.com
                  [email protected]
