Spartan Stuff in an Osprey
  • Snowride
    • Sep 2010
    • 297
    Well my Spartan is doing just fine unlike several others posting here. I do have several parts lying around including a spare tacon 1700, a 180 HK esc , a dual intake rudder and quite a few other things including 2 motor trays.
    What do you think I would see in terms of performance if I were to install these components on an Opsrey hull running twin 5800 3s to output 6S? Plan is to make a mount for the stock Spartan tray which holds the entire propulsion system so I can just "snap" it into the osprey or Spartan in a few minutes. If there is one thing Traxxas did right, it is the removable motor tray.
    Here is the hull I am talking about. http://www.hobbyking.com/hobbyking/s...Product=16519#
  • martin
    • 2869
    The Tacon motor is way to small for an Osprey, Even a Leopard 4074 that they fit in the rtr Osprey is to small. Their are a number that have used this hull on this forum using the Leopard 5692 motor on 6s with a T180 esc. The Osprey is a big boat when you see one in the flesh & much bigger than the Spartan.
    • Diesel6401
      Memento Vivere
      • 4203
      I have a Osprey and I am running a CC1717 and a CC Ice240 esc.
      The setup the OP wants to run is just not going to work at all for this size of a hull. A pursuit would be a better choice for what you want to use. JMHO
      - Diesel's Youtube
      - Diesel's Fleet
      • Snowride
        • Sep 2010
        • 297
        Thanks for the responses and as you can tell I really need help. Any other solid stable hulls I can transplant my modded Spartan guts to get performance similar in speed to my Spartan?
        • martin
          • 2869
          One of the most popular hulls around is one of the many versions of the 30-32" deep Vs, DF 32", Hor twister, HK Pursuit + a few more that are basically the same or simular design hulls all that work very well indeed. Their just a smaller version of the Osprey so if you like the Osprey then youll like one of these. The DF versions they have in the OSE store. Martin.
          • Diesel6401
            Memento Vivere
            • 4203
            Question already answered....
            - Diesel's Youtube
            - Diesel's Fleet
