Well got my Spartan wet today for the first time since changing all the drive hardware and motor/ esc over.... Ran good nonthing broke losened or fell off. With the exception of the motor collet loosening, (not a big deal) had the gps in and not very happy with the speed on 6s but everything was cool and no issues there. Will look into prolong up from a octura 447/3 to something with more speed potential. My gps read 34.5 mph....
but speed takes time . Still have some trimming out to do. She does chine walk or death wobble at higher speeds but that'll get worked out. And Kevin, jeffs .187 cable ROCKS!!! no problems here! Took the cable out after my run no heat issues or discoloration yet. There's still a large amount of grease on the cable but I'm gonna clean it off and re grease it. Just have to run that cable without the Teflon liner. As far as amp draw, couldn't confirm at this time still getting used to how the watts up meter works. All and all I'd say it was a successful voyage, with room to prop up for more speed. Special thanks to Jeff wholt, Kevin and all the people on this forum who have helped me! Any ideas on a "faster " prop? I'm running 6s lipos, seaking 180 & the leopard 1400kv motor.... Have the octura 447/3 prop currently with a speed if 34.5 mph.... Thanks! Also i had to higher the voltage cutoff to 3.2 volds as one if my packs had only 3% left and measured 9.87 volts at rest......
