Thanks to kevin I have finally put in mine seaking 180 and tacon 3674 1700 motor.
I went ahead and installed a 2075 traxxas servo to see how it does.I will be testing out on the water soon and posting my results.
Here is a pic of the tray.As you can see I have new tubing on the esc(OSE medium7/32" outside diameter with 3/32" inside diameter high flow Silicon tubing)(btw medium tubing was a lil tough to get on the 180 barbs.) but kept the original on the ends for the first run until I check everything.Then will use the new tubing.
Kevin everything look ok to you?
Thanks again.
Thanks again.
