Need help with ose water jacket
  • roadrashracing
    • 1462
    I am trying to put a waterjacket on my spartan motor but the o rings are breaking or poping out. I appied plenty of oil and am using a twisting movement, just really not a good morning.
  • wilsta67
    • Feb 2011
    • 203
    if your using the stock motor you will need to remove the 3 screws at one end of the motor, you will not get the jacket to slip over them. and be carefull not to strip the socket heads of the screws use the correct size allen key to remove them. to assist in removing the screws apply a bit of heat to the heads using a lighter, this will melt the locktite holding them in.
    • Rcforever27
      • 240
      You should also try using like dieletric grease i'n stead if oil . Oil will ruin the o rings.... If it's like motor oil or any petroleum based oil it'll ruin the o rings. They do go on kind of hard . Have one on the stock motor and one on my leopard that's currently i'n the boat. Also you might have to mildly heat up the screws on the motor to break the loctite loose. Good luck !
      Scott Spartan#1: castle hydra ice 240 castle 2200 Prather 220 turnigy 5.0 45c lipos with max amps water pump... Spartan#2: leopard 1800, octura 440 ,traxxas 8400 mah 25c lipos.....updated deeper hull....
      • Rcforever27
        • 240
        Oh sorry already mentioned the loctite trick above.... My bad....
        • roadrashracing
          • 1462
          I had the screws off, I tried greases and oils and all end up like pics, o-rings are junk now, any one know the size of them?
          • wilsta67
            • Feb 2011
            • 203
            it should slip straight on are you sure yo got the correct jacket?
            • wilsta67
              • Feb 2011
              • 203
              the jackets for the spartan motors or any other smooth case motor have a groove for the oring to sit in so im not sure how there comming out like that.
              the jackets for the castle creation motors dont have a groove as the fins are on the motor to hold the orings.
              • roadrashracing
                • 1462
                yep
                • roadrashracing
                  • 1462
                  Is there such a thing as metric o rings? I don't remeber the size I got but it looked right on.
                  • wilsta67
                    • Feb 2011
                    • 203
                    yeas there is!
                    this is a leopard jacket i have that fits the spartan motor.
                    Uploaded with ImageShack.us
                    • wilsta67
                      • Feb 2011
                      • 203
                      take some photos of the jacket you have.
                      same angle shots that i just put up , and post them here so i can see.
                      • wilsta67
                        • Feb 2011
                        • 203
                        because if it were the correct one the jacket would just slip straight on with out any dramas at all.
                        • roadrashracing
                          • 1462
                          pics
                          • wilsta67
                            • Feb 2011
                            • 203
                            pics
                            orings way to big
                            • wilsta67
                              • Feb 2011
                              • 203
                              take a photo of side without a oring
