timing and prop ?
  • davey
    • 163
    timing and prop ?
    Just got my Leopard 4082,,,,1500 KV and t180,,,whats the best timing for it,, and a starting point for a prop,......thanx Dave
  • martin
    • 2869
    I believe 15 degrees, But see what others say as well. Martin.
    • davey
      • 163
      yes 15 default.....I guess I'll try,,,as for the prop is the 445 a good start or a little small
      • spartanonfire
        • 65
        445 is a good start. I'm running a 645 with great results. No temp issues.
        • Diesel6401
          Memento Vivere
          • 4203
          Dependes on the motor wind. That information is normally provided by maker and seller normally should provide that info. Here's a perfect example. For what I know the 4082 1500kv is "Y" wind, but the very similar 4082 1450kv is "D" wind. The Y wind at 15 should be happy and should run good at that timing, but run 15* on the "D" wind and you will have problems.
          To answer your question 15 on that motor is fine.
          (i run my leopard "y" winds on seakings a 15, but I run my d winds at 7.5 which I may actually lower a little).
          - Diesel's Youtube
          - Diesel's Fleet
          • davey
            • 163
            thanx,,,,,and prop ,,,any suggestions,,,,,how about a 3 blade
            • LarrysDrifter
              Big Booty Daddy
              • May 2010
              • 3278
              Start with the X445. You may be able to use an X447/3, but check temps.
