Well after much reading and much advice from several I built what I believe to be the best most reliable every day all out fun Spartan. Keep in mind my goal here is not to be the fastest or race, just to have tons of fun without the headaches we usually hear about. So far so good.
There are documented issues with driveline and other problems if going with bigger motors so I stuck to a more "reliable" power source in terms of power and the Tacon 1700 is supposed to be very close to the stock Spartan in power, actually a little more. I am very green at this and therefor elected also to stick with the stock composite prop as they are a dime a dozen and I must say performs extremely well on this setup.
Modifications
Turnigy 180 ESC
Tacon 1700
Upgraded 2075 servo
EC5 connectors all around
Aluminum cooling jacket from OSE
Added additional stock water outlet to starboard side
New larger cooling lines all around from OSE
Dual intake rudder from OSE. Modded with home made bracket to use existing Spratan control arm and mounting holes.
Turnigy Nano Tech 6.0 3S
Wohlt's 150 size drive wire
Octura Teflon drive wire liner
Bottom line, I was able to sell the removed components for close to the same cost as the new components. By the time all was said and done my Spart cost me $309 delivered + $62 in mods. $371 for a bulletproof Spartan is not bad at all.
Working on graphics now and should update this in a few weeks or so.
Modifications
Turnigy 180 ESC
Tacon 1700
Upgraded 2075 servo
