Hot stuffing tube, Normal?
    • 9488
    biggest issue was traxxass was using oil to lube the shafts
    but greasing these every two runs or so should be plenty
    • Snowride
      • Sep 2010
      • 297
      The sad part is the tacon 1700 motor is about the same as the stock in terms of power and this is the stock prop. No signs of any hit by the prop as I am sure it would ding easily being plastic. Good thing is both the motor and esc are just warm to the touch after a hard run, time after time. Now if I can get this drive thing under control I should be able to enjoy myself.
        • 9488
        not even close my friend
        as I saw someones comments on traxxass the Tacon motor will outrun the stock POS any day of the week
        I think the stock motor can only run maybe 1000watts cont without over heating were as the Tacon can run 1500-2000watts with no issues (big difference)
        you can prop this motor up without issues unlike the POS stocker
        you are looking at rpms that are close but the the efficency of this motor is so much better
        • dag-nabit
          • Feb 2011
          • 775
          100%
          Kevin
          • GeoVW72
            • Jun 2010
            • 258
            WOW!
            Never seen one go that bad.
            I would not think that just no lubrication would cause that, the seaweed may have been most of the issue.
            what was the time frame between the two runs?
            a little rust may have formed if it was over a day, it doesn't matter how long it runs, if you don't plan on running it for a day you should clean and re lube the shaft.
            All the runs I do are without any driveshaft lubrication between them, however I do tear down the whole boat at the end of the session and clean everything.
            Now that you have everything else you also need to pick up some 1/4" KS tubing
            Team Boca Bearings
            S&G Design
            • spartanonfire
              • 65
              Looking at the prop shaft in the picture there seems to be significant scoring on it. Could be due to lack of lubrication, or possibly some debris got in there like some sand or dirt. The way the cable was twisted it sure looks like the issue was in the strut assembly. Since there was binding and friction in the strut while the motor was trying to force the cable to continue spinning, the cable just started warping and putting extreme pressure on the teflon liner. I'm thinking a floating bushing could have helped prevent this. I'd be careful about just replacing the cable assembly. With that much damage on the prop shaft there's a good chance the bushings have been damaged in the strut assembly. You might want to replace that while your at it, otherwise you could quickly eat through your new drive cable.
              Well I smoked the tube/drive wire pretty bad yesterday. I did not bother removing the drive wire and lubing it as I had only 1 run ( 8 mins) since it was last lubed. Towards the end of this run it started making noise like it was cavitating so I brought it in and found some seaweed so I thought this was the issue and returned it to the water. Punched it and it seemed to go better but was still a little noisy and regardless, I hit the low voltage cutoff after about 30 seconds. Brought it in and opened the hatch to disconnect the batteries and there was smell and smoke.
              Got home took it apart to view the damage. Holy crap, wire was twisted, a few small pieces of liner was all that was left, got so hot it melted part of the motor tray and servo bottom.
              Big question is. Did I do myself in by not lubricating after every run or are the original components just crap? By upgrading the parts should this be reliable? I already have the octura liner from OSE on order and a couple of new reinforced drive wires mentioned above on this thread. Good thing about the motor tray is they are only $4.95 so I ordered 3 just in case.
                • 9488
                Originally posted by GeoVW72
                WOW!
                that could have been what started the problem?
                • Snowride
                  • Sep 2010
                  • 297
                  #23
                  That is not scoring, maybe just residual grease. I just inspected it very closely and there is no scoring. A very slight discoloration towards the front but no marks to be seen or felt.
                  Seriously doubt it as there was only a long 6" blade of grass hanging from the rudder which I thought to be causing the sound of cavitation. As found out later, it was the mangled drive wire causing the noise.
                  Time frame was a couple of days. Boat is only run n fresh water. There are absolutely no traces of rust or foreign debris anywhere on the wire or in the tube and there should not be as I lubricate it every few runs with the grim racer grease sold here at OSE. I remove the drive wire and smear a thin coat over the entire length and then re-insert it.
                  Thanks for the info. When I was asking around to make this boat as reliable as possible I was pointed to the Tacon 1700 which was recommended for using the stock prop and was told power wise it wold have a slight advantage. I was only going from what I was told. Remember, I am as green as they get but learning fast.
                    • 9488
                    #24
                    Some over at traxxass give lots of miss info and don't know what they are talking about
                    but keep it going with this one man
