Leopard 4074 1774 kv...
  • Rcforever27
    • 240
    Lol yeah sounds good! I'll keep you posted !
    Scott Spartan#1: castle hydra ice 240 castle 2200 Prather 220 turnigy 5.0 45c lipos with max amps water pump... Spartan#2: leopard 1800, octura 440 ,traxxas 8400 mah 25c lipos.....updated deeper hull....
    • Rcforever27
      • 240
      On the batteries I have, the 5000 mah are 35c and the 6400 mah are 20c the watt hours on the 6400's are 59.84... Continuous discharge is 128 amps.... And burst is 192 amps....
      • Rcforever27
        • 240
        Wt are some good lipos tht won't break the bank but will be awesome i'n the spartan?
        • dag-nabit
          • Feb 2011
          • 775
          Now thast you have confirmed the numbers your 5000 are good, The 6400 should be OK, again if you don't go crazy propping up.
          If you are looking for decent batteries at a reasonable price look at the Turnigy Nano Tech 5000mah 40 and 45C 3S batteries from Hobby King
          Kevin
          • Rcforever27
            • 240
            Yeah I just was.... Those batteries really are good? The price seems way to cheap for the ratings.... About a year ago I bought a max amps battery for a rustler vxl 8000 mah 20c for 280 or so lol.... But I trust you i'n saying those are decent.... I guess if something happens to the cheaper batteries I won't feel ad bad replacing those batteries.... I'm gonna look right now at them.... Btw max amps isn't all they claim to be anymore.... Personal experience .....
            • Rcforever27
              • 240
              Wt about turnigy 4000 mah 40c? The "c" rating is more important on boats or for wt we're tying to accomplish? I mean the run time has to be enough.... I'm only looking for 8-10 mins..... If tht.... This way things won't heat up as much and it'll allow things to cool down ....
              • Diesel6401
                Memento Vivere
                • 4204
                mah is A LOT more then just ran time. mah and c rating a very important in determining the amout of amps your batteries can supply to the system. If your batts can't supply the proper amount of amps your lipos puff and or blow and other things could be destroyed also starting with the esc.
                Formula is aH x c rating = amps
                So 4.0 x 40 = 160 amps, to be more accurate you have to include the fact you never drain your lipos past 80%
                4.0aH x 40c x 80% = 128amps.
                8-10 minutes in FE boating is rare. 3-5 minutes is the typical average.
                * Don't use venom batts, they are notorious for being rated more then what they are capable off and blowing inside of boats. Stay away from those in the boating world. Turnigy are better then the Venom's.
                - Diesel's Youtube
                - Diesel's Fleet
                • Rcforever27
                  • 240
                  Ok thanks! That sucks though.... I have 4 of the venom ones already.... 2, 5000mah & 2,6400mah..... Ran the 6400 already no issues yet...... But do you kno the reason y they're not good i'n boats? Just do to the ratings not being true?
                  • Rcforever27
                    • 240
                    Btw I just bought 2 turnigy 4000mah 40c lipos...
                    • Diesel6401
                      Memento Vivere
                      • 4204
                      They can't handle the amp load FE boats can produce. In on/off road vehicles where the amp loads are much lower they are fine. Get into boating where the amp loads are a lot higher and they can't handle the amp demand.
                      I haven't read all the other post. Sorry for laziness, are you running 6s on this leopard 1774kv?
                      - Diesel's Youtube
                      - Diesel's Fleet
                      • Rcforever27
                        • 240
                        Gonna be ... Still waiting for parts to arrive ... I have speedmaster dual water pickup rudder , alum motor cooling jacket and I did the cooling upgrade this is all on the stock motor& speedcontroller ... Have not received any new stuff yet.... Kevin on here said that I should be fine as long ad I don't prop up tht much.... Prather 215 or 220 I made the mistake of getting a Prather 230 but didn't install it luckily he made me realize it's obviously tooooo big! Lol! And I have a grim racer prop thts close to the traxxas one tht has alittle less pitch than the traxxas one.... I think it's a 42x55 instead of 42x59...
                        • Diesel6401
                          Memento Vivere
                          • 4204
                          #27
                          When you start getting high up in the rpm range the amp load starts to get a whole lot higher. The s215 maybe your best shot. You have to keep things really low with those batts. Time will tell but you batts are def gonna get a work out. 6s2p would be better. You should buy 2 more of the same batts you just bought and run and make 2 sets of paralleled batts the series the whole setup together. That would give you 6s2p 8000mah 40c then your system would be less stressed.
                          I ran 2x 2s 5000mah 40c on my 1774kv leopard and am now going to be running 2x 2s 6000mah 25-50c nano-techs.
                          - Diesel's Youtube
                          - Diesel's Fleet
                          • Rcforever27
                            • 240
                            #28
                            you ran 4 total batteries in your boat? isnt that kind of heavy? and how would it handle?
                            • Diesel6401
                              Memento Vivere
                              • 4204
                              #29
                              Sometimes extra weight isn't a bad thing. Not sure about a Spartan don't/never owned one.
                              - Diesel's Youtube
                              - Diesel's Fleet
                              • Rcforever27
                                • 240
                                #30
                                Oh I thought you had one lol thts true tho...
