Motor Thought
  • Shaun78
    • Feb 2011
    • 416
    Motor Thought
    Leopard 3674 1700KV. This on 6S? Would this be a good choice on stock ESC. Max amps sayd 72 amps stock is rated at 80 i think? Would this make Spartan hit 50mph or more?
    Genesis (Bosncali Geico Beater) Leopard 4082 1500KV
    (63.7 MPH) Traxxas Spartan (same setup)
  • dag-nabit
    • Feb 2011
    • 775
    I think that motor would work with stock ESC. Only 100kv more than OEM motor, but it is a more efficient 4 pole motor.
    The question is, how reliable is the stock ESC with any motor???
    FYI
    The 1700kv motor is what I will be running, but with T180 ESC.
    Kevin
    • martin
      • 2869
      your probably see around the same speed with that Leopard as the original motor but more reliable & you might have to prop down slightly because of the increase in rpm. Nearly 38000 rpm will be quite high for a mono hull of that size. Martin.
      • Shaun78
        • Feb 2011
        • 416
        Kevin, u r running that motor? 3674 1700KV?
        • dag-nabit
          • Feb 2011
          • 775
          I will be, in both Spartans, if it ever warms up here enough to thaw the lake.
          I have Tacon 3674 1700kv motors. I ordered Leopards, but was shipped Tacons. The research I have done suggests they are the same motor, just re-badged.
          I'm hoping they prove out to be reliable.
          I also have a couple other motors I can play with if these don't give me the result I'm looking for, but I'm confident they will. I may play around for some top end speed, but mostly my daughter and I just chase each other around the lake, so if I can run 47 - 53 mph with good control and reliability, I will be a happy camper.
          Here is my current setup, both trays are the same configuration.
          T180 ESC
          Tacon 3674 1700kv
          Aluminum Water Jacket
          Spektrum MR3000 rx
          Upgraded Collet
          Running 6S
          • Shaun78
            • Feb 2011
            • 416
            I could use my upgraded spartan ALum. jacket. What prop r u thinking? Stock? it should be able to hit 50mph as its a better,more powerful design than the Stock setup. Hmmmm I wonder if stock ESC will work, I have a new seaking on its way but if i dont need it. Probably better off using it though
            • dag-nabit
              • Feb 2011
              • 775
              Your call on the ESC, I choose to switch mine out without ever powering it up. I figure if it torches and takes a set of batteries with it, it isn't worth the chance. More importantly, I don't want the ESC to flare up on my daughters boat while she is hooking up batteries or something.
              You might have a good one, and not have any issues.
              For props I'm not sure, won't be stock though. I have an assortment to try and will settle on the one that gives me good speed, good hole shot, and stable ride.
              I agree that it should be possible to hit 50 with the stock prop on this setup in light of the fact a couple (few) guys have managed 50 on the stock setup.
              Maybe a Prather 215 or 220, or I have a couple 3 blades I want to try. Will depend on amp draw with this set up, as well as performance.
              Kevin
