Castle 1717 Direct FIT?
  • dag-nabit
    • Feb 2011
    • 775
    Load up on the 1580kv car version here.............
    http://www.kershawdesigns.com/
    Looks like they have the Leopard 4082 1500kv in stock as well.
    Kevin
    • mavdriver
      • Dec 2010
      • 65
      Thanks Kevin I `ve been trying to get this motor for a while I just order and paid for a leopard 4082 / 1500 from kershaw , now just need to wait for it to get here , so i can play with my Spartan .
      • mavdriver
        • Dec 2010
        • 65
        the CC1717 does fit, a little snug with the water jacket
        almost the same kv as the CC1520 1600kv
        Brushless I got the air CC1717 1500 KV what size prop are you running on yours ? Im also got a T180 , 40c 6s 5000 lipos that i willl be using .
          • 9479
          with that motor I would start with a 45mm prop and work your way up to 50mm
          and it looks like your going to run 6s2p 10,000mah
          lots of amps man
          good job!
          • mavdriver
            • Dec 2010
            • 65
            I meant two 3s 5000 in series oh well i might go with two 6s in parallel but i would need a bigger esc like a hydra 240 or swordfish
              • 9479
              Oh ok, so two 3s 5000mah 40c in series..
              running parallel has nothing to do with needing a bigger esc
              • mavdriver
                • Dec 2010
                • 65
                Got it was thinking if i go bigger prop
                  • 9479
                  #23
                  Go can go upto a 50mm prop with this motor on with two 6s 6000mah 40c packs if you want on that esc
                  But do run a external bec os some sort just for more insurance on the esc..
                  • mavdriver
                    • Dec 2010
                    • 65
                    #24
                    Sounds good will run external bec .
                    • Diesel6401
                      Memento Vivere
                      • 4203
                      #25
                      Do you think Torque roll would be an issue with that size prop?
                      - Diesel's Youtube
                      - Diesel's Fleet
                        • 9479
                        #26
                        not much at all with a 45mm but getting to 50mm there could be some?
                        • mavdriver
                          • Dec 2010
                          • 65
                          #27
                          Looks like the hampton 1717 waterjacket doesnt fit correctly on the CC1717 air motor way to loose maybe it needs bigger O rings i also notice the air motor has the each side of can flat not completely round is the car motor has fins that are round around the motor ?
                            • 9479
                            #28
                            yeah, the air motor is made for the T-Rex 600
                            and needs to fit in the chassis
                            • mavdriver
                              • Dec 2010
                              • 65
                              #29
                              so my guess would be is that i need fatter O rings if i want to use the water jacket .
                                • 9479
                                #30
                                yes, give it a shot
