It comes water resistant but I am concerned if it flips over and fills with water. Is there a way to waterproof the esc like the traxxas esc?
Waterproofing T180 esc.
miss gieco cc 1518 62.1mph [/COLOR][/B] Delta Force 33" cc 1717 -
seaking website says its waterproof so maybe it is allset. JPriami, when you flipped yours did water fill the hull and soak the ESC? If so then it must be waterproof.Genesis (Bosncali Geico Beater) Leopard 4082 1500KV
(63.7 MPH) Traxxas Spartan (same setup)Comment
They arent water proof. They are water resistant. Sometimes when they get submerged or a little water in the case,they will act up and not work properly untill they get dried out completely.I would take the case off and spray it with Corrosion X and let it sit for a day or two.There is a gasket on there also. I put the gasket back on and also used silicon,but it still wasnt water proof. I dont know what to tell you about water proofing it. Maybe others here can give you pointers on that one. Id like to know myself.Comment
Here you go shaun.... http://www3.3m.com/catalog/us/en001/...er/output_htmlmiss gieco cc 1518 62.1mph [/COLOR][/B] Delta Force 33" cc 1717Comment
