I've been experiencing heat issues with the flex cable & stuffing tube on 6S.
First bit I noticed was there was rainbowish discoloration on the stuffing tube when i took the tray out of the boat for some work I was doing. That discoloration is a sign of high heat.
It also got so hot it began to melt the plastic holder at the back of the tray near the transom. This was noticed before my modification of moving the strut and tube btw.
I grease my flex cable every one to two runs so there is no way it's a problem with not maintaining the cable with grease.
Anyways i would like for all the 6S runners to check the tube for discoloration or at least put your fingers on it right after you run to see if it's really hot.
The reason being is I experienced my flex cable sizing up today and not turning. Luckily my setup is over powered what happened was the boat stopped but the motor tried to spin the cable and ended up spinning the collet over the end of the cable. I sent the rescue boat to go get my boat thinking i lost the prop the way it was acting. Then got it back to find the driveline was binding. After the boat cooled down it spins freely.
There could be a potential problem with the driveline sizing up and that could fry your eletronics IF this is happening.
I appreciate the heads-up. I'm just about to complete mods and anxious to run it. I'll watch for the stuff tube issues. After all of your success and now this!
