Traxxas Spartan Prop Selection?
  • djmaincheese
    • Dec 2010
    • 347
    I posted this in the Prop Forum Section but it might be better suited here..
    You may have seen that I upgraded the Motor and ESC in my Traxxas Spartan
    I installed the Leopard 3674 1300KV Motor and Sea King 120A ESC,
    I tried the running the Grim Racer 42mm X 55mm but she seems kinda sluggish. I switched back to the stock 42mm X 59mm and it was a little better.
    Im wondering what you guys think I should possibly try, granted it may take a couple to find the sweet spot but at least I have a motor and ESC that can push this 36" hull with no heat issues.
    Should I try the Prather 225 or the Octura X445, or something a little bigger?
    Any help would be greatly appreciated.
    'Im running 2 Venom 3S2P 6400mah Batteries so they are a bit heavier than the normal 5000mah lipo's out there that most people seem to be running.
    Here is a short clip of some passes....., until i get a gps or radar gun I have no idea but I know it's not even pushing the 50mph mark
  • Make-a-Wake
    FE Rules!
    • 5557
    Did you temp it after a good run????
    Try an x442.....or an x640
      • 9488
      I think he is after something bigger
      his motor and esc were only 63-64*
      • Make-a-Wake
        FE Rules!
        • 5557
        Yeah, I was trying to interperet what sluggish meant. The x640 actually has more total pitch than an x445 and I thought it may work better as wobbly as the Spartan is, more thrust, less diameter.
          • 9488
          It took me a while to get what that ment to..
          • Rumdog
            • 6453
            36" boat = more diameter needed. I'd be worried about the 120 amp esc though.
            • Make-a-Wake
              FE Rules!
              • 5557
              For more diameter, a 445 would be a step up but I'd try the M series
                • 9488
                I think right now he is only pulling about 30amps
                • djmaincheese
                  • Dec 2010
                  • 347
                  Im going to order the Octura M445 and the Prather S225, hopefully get them in time for the weekend :)
                  • Make-a-Wake
                    FE Rules!
                    • 5557
                    The S225 is ALOT of prop...................almost 47mm and aggressive pitch................it's too much prop in my opinion............try the M445 first.
                      • 9488
                      Oh man!
                      • tomjr
                        • Feb 2011
                        • 17
                        Must the prop be balanced and sharpen ?
                        I can see there is a big difference in price....
                        Can we just use the normal not balanced not sharpen props ?
                        Please advice
                        • stjupau
                          • Jan 2011
                          • 1
                          Please advice
                          I would definitely have the prop balanced and sharpen, for peek performance and minimum stress on your "Drive System" (Motor, Bearings, and Flex cable).
