Thermal Issues with the New Traxxas Spartan
    • 9479
    Any thoughts on this Darin?
    • Darin Jordan
      • 8332
      Nothing that hasn't already been considered or said before.
      Darin E. Jordan - Renton, WA
      • T.S.Davis
        • 6228
        Darin.....ya coward. haha
        A 4 minute Q mono that runs 50 right out of the box and doesn't burst into flames? Sounds like a perfect setup.
        Any longer than that is unrealistic for an electric boat IMO. Especially one that's been marketed as ready to race. That's just me though.
        How hot is hot? Do you have temps or is the speedo thermalling and dialing down the power? It could be that it's the voltage cut off after 4 minutes. My kids Slash drops the power when the voltage gets too low. If I run any of my Q sprint boats for 4 minutes they'll go thermal nuclear.
        Noisy person
        • Diesel6401
          Memento Vivere
          • 4203
          Originally posted by Rumdog
          Your untimes are too long. 4-5 minutes from what I'm presuming is 6s1p.. Cut the runtime down and check temps throughout the run. The REAL problem is a 540xl can in a 36" mono. It just isn't quite enough.
          Doesn't Traxxas have a deal with CC, like they did with their e-revo's... They should have stuck a 1518 or 1520 in the hull from the beginning. Could have worked a deal with CC before they started the super discount deal to get rid of all the 1518's or 1520's. Just a thought. The plastic hull prob wouldn't have survived those motors though
          - Diesel's Youtube
          - Diesel's Fleet
          • JimClark
            • 5902
            Billy Graham
            • Alexgar
              • Aug 2009
              • 3522
              to small and not eff motor
              • Grimracer
                • Nov 2008
                • 656
                • Jeff Wohlt
                  • Jan 2008
                  • 2716
                  #23
                  Many times, running higher speeds mean less drag and better efficiency.
                  www.rcraceboat.com
                  jwohlt5362@yahoo.com
                  • LarrysDrifter
                    Big Booty Daddy
                    • May 2010
                    • 3278
                    #24
                    I love the 40 x 82 1500 Leopard motor.I have 2 of them.One was in my 37" cat and the other in a 33" DF copy.Both boats ran awesome on 6s with way more than 5 minutes of runtime.I know a 33 isnt a 36,but 3" shouldnt matter that much with an efficient motor.This motor has my vote for the Traxxas boat.
                    • Rumdog
                      • 6453
                      #25
                      But, then youre up to $500.00 for a cheesy plastic boat..
                      • LarrysDrifter
                        Big Booty Daddy
                        • May 2010
                        • 3278
                        #26
                        Yep.I wouldnt do it either.Run the toy boat on the batteries it comes with and get an FG hull for speed and the build it your self experience.
                        • LarrysDrifter
                          Big Booty Daddy
                          • May 2010
                          • 3278
                          #27
                          And Im a Fast Electric Adict now too!Previous post brought me to 1,000.
                          • Doug Smock
                            Moderator
                            • 5264
                            #28
                            Are you running the stock plastic prop? Is the boat running wet? Any video?
                            While I agree the motor is a bit small for a mono that size you can probably land on a prop that will make it happy.
                            Doug
                            MODEL BOAT RACER
                            IMPBA President
                            IMPBA 19887L CD
                            NAMBA 1169
                            • djmaincheese
                              • Dec 2010
                              • 347
                              #29
                              Hey Doug
                              Yeah still running the stock prop 42mm X 59mm. What do you mean by "wet" Water in the hull?
                              I only have some short clips of it running in training mode, I will try get a video from full charge to thermal shutdown and we will see how long she lasts. I may unplug the heat sensor from the rx and use a temp gun to get an actual reading!
                              What about a more efficient aluminum cooling jacket or that aluminum tubing that wraps around the motor. I don't think the rubber jacket they supplied does a good job of keeping it cool.
                              I guess it's just going to take a bit for some real world testing with different props, batteries and possibly motors to get this thing running great.
                              • Doug Smock
                                Moderator
                                • 5264
                                #30
                                By "running wet" I mean does the boat have a lot of wetted surface? The wetter the hull runs the higher your motor temps will be. A free running boat will be faster and run cooler. I'd wait on the water jacket for now. Have you verified that the water cooling is working?
                                We'd be interested in seeing some video of the boat running full speed back and forth in a straight line. Some transom pics would help too.
                                Try not to run it till it thermals.
                                Doug
                                MODEL BOAT RACER
                                IMPBA President
                                IMPBA 19887L CD
                                NAMBA 1169
