Traxxas Titan
This topic is closed.
  • alvinsmith75
    • Jul 2008
    • 635
    #136
    ^^^^^^^^^^^I did $4500+ last year and at least $2000 so far this year, thanks to the 5T.
    • forescott
      Hopelessly Addicted to RC
      • 2686
      #137
      Ouch! You must be single!
      • forescott
        • 2686
        #138
        If she reads this you might be divorced!
          • 9479
          #139
          I dunno? Just got the e-mail yesterday. I've probably only spent about 1000-bucks over the past 2-years.
          oh man! I better give Tower a call then..
          • laxoholic93
            • Feb 2010
            • 14
            #140
            looks like a very sooth running hull too!!!
            • forescott
              • 2686
              #141
              PM me your e-mail and I will forward it to you if you want to take a look.
                • 9479
                #142
                Not sure if I follow?
                • forescott
                  • 2686
                  #143
                  Ill forward you the e-mail they sent me for the gold members sale. You wouldnt be able to use it but you could check it out.
                  • forescott
                    • 2686
                    #144
                    High-Performance Prop
                    Titan’s surface-piercing prop is optimized to get the hull on plane quickly without cavitation and to run at maximum speed with the least current draw. Traxxas engineers spent many hours testing prop configurations to find the perfect balance of performance, efficiency, and durability. Molded composite construction makes the prop light and tough, and no balancing or sharpening is require
                    If traxxas spent as much time as they say the did on the prop, I dont see there being much room for propping up. But hey, 50mph in a hull this big is a big feat IMO!
                    • BondoBrushless
                      Banned
                      • Feb 2010
                      • 156
                      #145
                      BUSHINGS ?
                      TRX has a bearing supported drive also as a hop up.
                      • forescott
                        • 2686
                        #146
                        Where do you see the hop-ups??
                        • BondoBrushless
                          Banned
                          • Feb 2010
                          • 156
                          #147
                          • forescott
                            • 2686
                            #148
                            Oh! under accessories. Duh!!
                            • BakedMopar
                              No Mo Slipah
                              • Sep 2009
                              • 1679
                              #149
                              I'm sure Traxxas propped that boat for 6s. Thats why the 4s numbers are a little low (but not too bad) Reason is everyone that buys it see 50+ on 6s on the box, will go straight to 6s.
                              • forescott
                                • 2686
                                #150
                                What exactly is a composite propeller? It can't be plastic can it? At 35000 unloaded rpm?
