Genesis R Model motor Kv ?
  • MikeP323
    • Jul 2015
    • 96
    I have an R model Genesis with the two 4082 SSS motors - is there anyone who might know the Kv of these motors? The paperwork that comes with these boats is worthless.
    Thank you in advance.
  • koen
    • Mar 2020
    • 358
    i can be a 2200kv,tfl sells them as an upgrade
    • MikeP323
      • Jul 2015
      • 96
      Genesis Motor Kv
      Koen thank you for your reply - I have been running the boat with 4S batts and it seems a bit slow to me. Will try 5S as I do not believe 6S batteries will fit in the boat. If the motors are 2200kv 6S might be too much anyhow?
      • koen
        • Mar 2020
        • 358
        you can run the motors on 6s but check temps and for props 43mm is max prop dia (a set of ABC 1715-17 give a lot of speed) it take some time and testing to find the sweet spot
        • MikeP323
          • Jul 2015
          • 96
          Genesis Props/motor Kv
          Thanks again Koen. Locating a set of those ABC props will not be easy but I will give it a shot. I do have a set of ABC 1815 -17 so I could try those while checking the heat. Maybe try them with
          5S first and then sixes if I can get them in and out of the boat. Those are a tight fit.
          • PlayerUnknown069
            • Apr 2023
            • 72
            Is this your boat? https://tflnorthamerica.com/product/...fshore-rudder/
            If so you are looking at 2075kv. I can’t find the spec sheet but I would say yes to 6s as a SAW build if you could make it fit. Now prop size will be important also those seaking 180s will get hot if you are not careful. They recommend 2 4s packs but I think that is because of fitment not the motors or esc limits. The Zonda runs on 6s with the same setup, actually I think the Zonda comes like 2200kv. Again 6s would be a drag style setup not for sporting around.
            • Alfa Spirit
              • 2131
              • MikeP323
                • Jul 2015
                • 96
                Genesis/Zonda?
                If so you are looking at 2075kv. I can?t find the spec sheet but I would say yes to 6s as a SAW build if you could make it fit. Now prop size will be important also those seaking 180s will get hot if you are not careful. They recommend 2 4s packs but I think that is because of fitment not the motors or esc limits. The Zonda runs on 6s with the same setup, actually I think the Zonda comes like 2200kv. Again 6s would be a drag style setup not for sporting around.
                Player thanks for the reply. I believe what i have is the Zonda with the blue and gray paint scheme. I think i will stick with four or five S in it as that is fast enough. I have a few other boats for speed that I can slip those six S batts into. Again thank you.
                • MikeP323
                  • Jul 2015
                  • 96
                  ALfa - Thank you for your reply. I do believe what I have is the Zonda with all the trimmings. In any case I will stick with four or five S as I mentioned in my reply to Player and use the other boats for six S.
