What prop for the widowmaker ?
  • lucozader
    • May 2009
    • 144
    which prop hsould i get ?
  • bmaxx
    • 27
    The Octura M435 and Y535 props seem to be working good for me now. I am using a Mamba max esc and a 3cell LiPo.
    • lucozader
      • May 2009
      • 144
      thanks, the m435 is on ebay, i think i'll try that
      i got a new esc that can take 3 cells
      any other tips on setting up the boat ?
      • widow*shaver
        • Dec 2009
        • 6
        I noticed a big difference on the Aquacraft Grimracer
        40x52/3. I flipped upside down after the second strait away. I was glad someone with a fishing pole was able to give me a tow. The prop is made for a larger shaft so some modification is needed. I used two cut pieces of brass tubing from my local hs. inserted the small tube into the larger one, then notched the end with a small file. The shaft nut does not go in all the way so some lock tight would keep it from falling off.
        • Jeff Wohlt
          • Jan 2008
          • 2716
          The newer 3 blade 435 or whatever it is. My buds boat is fast with it.
          www.rcraceboat.com
          jwohlt5362@yahoo.com
          • OshkoshMono
            • Apr 2010
            • 207
            Yep! The best prop for this boat! I've tried quite a few. Best one I've found anyway....
