water cooling
  • Crash
    • Oct 2015
    • 313
    water cooling
    I do not see much if any water coming out of the discharge hole on side of boat.
    I blew the lines out with air but still not seeing water discharge.
    Has anyone ever enlarged the pick up holes?
    • 8011
    It is common not to see water exiting the cooling systems on many FE boats, especially at lower speeds. As long as the cooled components are not too hot then don't worry about it.
      If your rudder is trimmed a little one way and the hole is on the side that water is flowing around it (I forgot what side, maybe someone can chime in) then that could be an issue. Also it helps if the slot meets (or comes real close) the sharp edge of the rudder. I drill out my fittings on the ones that have tiny holes. Take the hose off the rudder and blue through it...if it's very hard to get air through it then water isn't traveling very well either. I'd looks for any kinks, partial kinks, restrictions, debris, machining chips. It may help to narrow down the restriction by blowing through the rudder hose going to your first component but have it disconnected....that will give you an idea of how much the hose it self lets you blow through it. Then hook up a hose to your cooling jacket. Blow through it leaving one side open. Same thing with the esc. You can see where I'm going with it. That should be some good ideas to get you going. I alway like water spitting from mine even around 10mph. Fluid is right that some don't spit water out till high speeds but I'm not really ok with that so I make efforts to correct it.
      • arrover
        • May 2015
        • 322
        How are your water lines routed? The left picture is how my Voracity came from the factory. The front "U" loop on the ESC was half kinked. The cooling line also exited the bottom of the motor instead of the top. The right picture shows how I rerouted the lines to (in my opinion) fix the cooling. This is how I ran my Voracity while doing a ton of prop testing and I had cooling at fairly slow speeds. You just need to switch the lines around. No need to buy any new tubing. It might be worth a try.
        ProBoat Zelos 36 Twin, Voracity 36, Impulse 31, Stealthwake 23, and HobbyKing Flowmaster Videos
        • Crash
          • Oct 2015
          • 313
          Thank you
          that did the trick , she spitting water now.
          Dan
          [ATTACH=CONFIG]138507[/ATTACH] [ATTACH=CONFIG]138508[/ATTACH]
          • arrover
            • May 2015
            • 322
            Excellent! That's good to hear.
            • rcboone2000
              • Dec 2011
              • 69
              Cooling
              I installed a second cooling pickup to mine it really helped.I have pushed my stock boat to its max and finally over the speed control amp limit it still stayed cool20151106_095122.jpg20151106_095110.jpg
