The Voracity tuning thread
Thanks for the info kfxguy! I'm going to restate my numbers in this thread just so the info is here.
On 6S:
Stock, untouched prop - 48.7mph
x645 - 51.0
x642 - 42.9
On 4S:
Stock, untouched prop - 32.8
x645 - 32.8
x642 - 30.0
IMG_9382 (Medium).JPG IMG_9383 (Medium).JPGLast edited by arrover; 08-28-2015, 11:19 AM.Comment
It sounds like some of the Voracitys are shipping with slightly incorrect waterline routing. The front waterline on the ESC is very short and is on the verge of being kinked. Also, the water should exit the top of the motor to prevent any air from getting trapped inside the cooling jacket and decreasing the cooling.
- Take the short hose off the front of the ESC.
- Remove the medium length hose that exits the ESC and goes to the top of the motor.
- Disconnect the hose on the other end of the motor (no need to disconnect it from the hull fitting.
- Take the short hose and connect it from the ESC exit to the bottom motor fitting.
- Take the medium length hose and put it on the front of the ESC in the same U shape as before.
- Connect the hose from the hull fitting to the top of the motor.
Now the water comes out of the top of the motor and exits the boat. The hose lengths fit perfectly, the motor should cool better, and the ESC loop isn't kinked anymore. The new routing is shown below.
IMG_9363 (Medium).JPGLast edited by arrover; 08-28-2015, 11:13 AM.Comment
I forgot to add. It seemed very very sensitive to trim tab position. When I had them flat, it would not bounce. And slight angle up and the nose would porpoise. Almost flipped it a couple times.
I'm having a hard time with this. I want to keep this thing as stock as possible but then I have drawers in my tool box full of motors and escs. I guess I'm gonna have to wait. But I'm getting antsy.Last edited by kfxguy; 08-21-2015, 09:29 AM.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
I'll be interesting in seeing what you guys come up with...
Are any of you monitoring the temps on your motor wire plugs??Darin E. Jordan - Renton, WA
"Self-proclaimed skill-less leader in the hobby."Comment
Personally I think that's too much prop and I think the abc with less pitch will beat it and pull less amps. But I'll find out. I have one of those too. And a m447 I need to try.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
That's great that you have all those props. I will wait for your results before I order one. ThanksComment
I have pretty much everything that is popular. I used to squeak when it can to buying props but I don't anymore. I'm ordering a couple more today and I has some other abc stuff coming.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
