Sonicwake v2 part
  • Rooki1
    • Jul 2023
    • 4
    Sonicwake v2 part
    hello all,New to the forums
    I have a v2 that I need help with, I ran the boat on 6s SRD speed 250c pack and in few seconds it stripped the flex shaft from the Coupler, they are on order from dose, but then I went and opened the in hall stuffing tube assembly to make sure all are aligned to find the rubber from it that holds the stuffing tube from inside the hall is shredded, I can not find the part to replace it nor if I did I can't tell the direction it needs to be installed.
    Please help me find the part, I have been messing with chat B.S WITH HH no number to call for support.
    Thank you all
    Ben
  • Bande1
    • Mar 2023
    • 680
    you dont need that.
    • leski379
      • Jul 2023
      • 95
      Ben,
      I believe the only way to get the rubber bushing you need is to order a whole new stuffing tube, it comes with it. Maybe a few layers of heat shrink in a pinch would work.
      • CJPB32
        • Aug 2022
        • 72
        Maybe find a rubber grommet that will fit? Harbor Freight sells a cheap grommet kit with many sizes.
        • Rooki1
          • Jul 2023
          • 4
          Not a bad idea to order a set to keep on hand.
          I will check with HF to see if there is anything I can use
          • revunmop
            • Mar 2024
            • 1
            To me this is a good and effective idea.
