Hi I have a impulse v2
Upgraded shaft(ose)
Sharpened and balanced m445 prop
Dual rudder kit(esc has its own water pick up and outlet as does motor)
I run two 3cell 6000mah batts(never gets above warm)
I want to upgrade my motor to the leopard 4074 2000kv vs stock 1800kv(which is just a little longer than stock)
My question is
will it fit the stock motor mount(both are 540 cans)
And how much of a power/speed difference will I see
And my esc should handle the amperage drawn if I'm correct?
Thank you for reading and any advice would be helpful even if its not about my question.
Upgraded shaft(ose)
My question is
