Impulse 31 Deep-V BL RTR V2
  • Nutbar
    • Aug 2012
    • 42
    I just noticed that there is a VERSION TWO of the Impulse 31 that looks like it is strikingly similar to the Traxxas Spartan. http://www.horizonhobby.com/products...v2-PRB4250B#t1
    I was wondering if anyone had any reviews of it yet, and/or how it compares to the Spartan? From what I can tell, it's a bit smaller, has a fiberglass hull, and is a little cheaper. What does everyone think?
  • Make-a-Wake
    FE Rules!
    • 5557
    It has a different motor and a new 80a speedo, bout time they went up on the speedo as the original stock motor, and this one I imagine, can take a good amouont of prop. Now folks can get into the low 40's on the stock setup with just a prop upgrade.
    • Diesel6401
      Memento Vivere
      • 4204
      Spartan is a over-priced hunk of plastic. Save your money and get the impulse. Built by a racer and not some advertising company that was more worried about the stickers and the name rather than its performance.
      S3 iPhone killer via Tapatalk
      - Diesel's Youtube
      - Diesel's Fleet
      • gtrcguru
        Radio Control Guru
        • Jul 2012
        • 160
        never owned a spartan but i do own an impulse v1 and it is a fast and stable boat when set up right.
        58" Venom Segad-48" Prather Deep Vee-41" Dumas 1/8 Hydro-34" Saga C1-32" Venom KOS P1-31" Pro Boat Impulse V1
        • Kraemer
          • Sep 2012
          • 12
          I hope they fix all the leaking problems in the new version. My Impulse 31 was leaking through the drain plug and all the screws from the trim tabs out of the box
          Still waiting for Horizon to get back to me in terms of warranty.
          Greetings from New Zealand!
          • Niky
            • Sep 2012
            • 61
            Hi Guys!
            Did anyone allready hear something (bad-good) about the new "animal" of the Proboat, I mean the new Impulse 31 V2?
            Thanks,Niky.
            • mannytx1
              Fast Electric Adict!
              • Oct 2012
              • 99
              Diameter reduced, back- cuts, balancing and detongueing , sharpening, 42x55 -- 40x55
              connector 4mm Gold
              cooling hose 1/4x.170 O.DxI.D
              servo does not work
              esc does not work for high volt cutoff and cutoff type ldle, (can not be programmed with programming card)
              not recommend this boat
              after 10 day, proboat not have parts for warranty, out of stock
              incredible disservice
              • Niky
                • Sep 2012
                • 61
                Hi Guys,
                does it mean mannytx1, that you run your IM on 6s?
                And if you did, please tell us how it seems?
                Is it the truth what they say at Peoboat that the New IM is copatible with 6s?
                Thanks.
                • mannytx1
                  • Oct 2012
                  • 99
                  100_0213.jpg100_0217.jpgProblems begin
                  servo does not work
                  • mannytx1
                    • Oct 2012
                    • 99
                    Impulse 31 v2 improved
                    The problem was the color. I change the color and no more problems LOL…..
                    -Battery 5S 4000 mAh 40C
                    -Propeller (Battery 5S, motor timing LOW)
                    42x55 45.4 mph
                    M445 46.3 mph
                    42x55 the tongue removed 47.2 mph (timing high 8% more speed and Amp)
                    M445 reduced to 42mm diameter 50.8 mph (timing high 8% more speed and Amp)
                    -Cooling hose 1/4x .170 O.DxI.D
                    -Connector 4mm Gold battery
                    -ESC front, more weight to the front, batteries more near the CG
                    -CG 30 % 8” ¾ or 9”
                    -Improves cooling system
                    -The antenna of de other side
                    -Reinforcement of the hull and hatch cover with fiberglass and resin
                    -Modify the original turn fins
                    - flex shaft (Miss Geico)
                    -Adjustable trim tabs
                    -Homemade bushing
                    -Hatch lock
                    -The stock 1800KV motor and ESC 80 Amp (only 5s)
                    -weight of the boat 4 ½ pounds without battery, with battery 5 ¼ pounds
                    Manny
