Ok so some embarassing new guy questions
I read that the common consensus is to upgrade all the connectors in the Impulse 31 to 5.5mm bullets. What exactly is the benefit in doing that?
I assume this means pulling out the deans connectors the Lipo's plug into as well as replacing the smaller bullets the motor plugs into the ESC with? Are the Deans really that bad?
If I'm just going to run stock for a while on 5000Mah 40C Lipo's then will I be ok without doing the upgrade?
I assume that if I do a prop upgragde (definitely on the cards) and the motor starts drawing more amps - then this is when I'd really need to upgrage all the connectors? What happens if I don't upgrade? Leads get hot??
Cheers all!
Cheers all!
