Warning: Trying to access array offset on value of type null in .../vb/bbcode/url.php on line 114 any solid motor upgrades for the impulse 31 yet?? - Offshore Electrics Forums
  • Jpope
    • Feb 2011
    • 30
    ok, i've had this boat for a month or two now and ready to upgrade motor for some real pond bashing fun. I'm looking for a good combo to get this boat in the mid 50's with no issue's. Has anyone got a tried and true set up? i want to beat the pants off my neighbors stock spartan if possible. Any help or advise will help.
  • Darin Jordan
    • 8335
    I've been using one of these: http://www.horizonhobby.com/Products...ID=THPM18A2100
    EASILY into the 50's!
    Darin E. Jordan - Renton, WA
    • Jpope
      • Feb 2011
      • 30
      Thanks Darin, is this a direct drop in or do I need to purchase a different motor mount? Awsome boat by the way!!
      • Darin Jordan
        • 8335
        Direct... Most of the motors generally available out there (Castle 1415, 1515, Neu's, etc.) will drop in. I designed the motor mount with the slots, and the positioning of the surrounding structure, etc., to be able to accommodate a much larger motor. Also laid out the battery trays to be able to handle a LOT of battery. I think you'll find that there is no issues maintaining CG with any number of motor/battery combos.
        If you want REALLY good performance, and a little less runtime (not quite as much a RACE setup)... you can go with the 1900KV motor instead of the 2100... This will turn more prop, and will still get you clearly into the 50's, but will be a little easier on the system and not quite so high-strung...
        • Jpope
          • Feb 2011
          • 30
          Thanks for the help, ordering it now. Not into racing yet, just good old pond bashing. Live in Florida so there's a boat load of neighborhood ponds with beginners like myself tearing them up. I just like having the edge like anyone else. I'll you know the outcome of my upgrade.
          • Jpope
            • Feb 2011
            • 30
            What prop do you use with yours??
            • Darin Jordan
              • 8335
              If you got the 1900KV setup, then I would start with an X645 or an ABC 45x55. You'll also have enough power to make an X447/3 work... Any of those would be quite substantial upgrades in speed.
              You ARE going to have to update your ESC as well... I'd suggest a 120A minimum... You can get away with running 4S1P if you have larger packs, but might consider running 4S2P to get the best run-time.
              A Castle Creations/Neu water jacket from OSE will fit, diameter-wise, but because of the tab placement on this motor, you might have to see if Steven sells one that is a little shorter than the 1515 sized jacket. it's too long to fit properly as supplied and needs to be shortened.
              Lots to consider when doing a motor upgrade, for sure.
              • burgerchow1
                • Jul 2011
                • 50
                I just threw in an aquacraft UL-1 2030 kv motor. Direct replacement, didn't have to change a thing and on M445 prop, got more speed out of it.
                • Darin Jordan
                  • 8335
                  That's fine... You could have just as easily put the right prop on it, and gone faster as well... There isn't anything magic about running 2030KV vs running 1800KV, if all the other motor parameters are the same. Just delivering similar power in a different way (RPM vs. Torque)... If you prop the 1800KV motor to have a similar pitch-speed, you'll get similar speeds...
                  It all depends on what you are trying to accomplish. The owner who started this thread wanted to get into "the 50's"... you aren't likely to do that... not for very long, with either of these motors... The motors I recommended he try WILL...
                  • Jpope
                    • Feb 2011
                    • 30
                    Thanks Darin, Im going with the 2100kv set up and start testing props. Should have motor by the end of next week along with a couple water jacket options to try. I'll post some results I get my new stuff installed. Thanks again for the advise!!
                      • 9488
                      Or you could save a good amount of money using a leopard 4074 2150KV motor from Steven here at OSE and possibly have more power??
                      95 bucks
                      http://www.offshoreelectrics.com/pro...o-4074&cat=148
                      • Make-a-Wake
                        FE Rules!
                        • 5557
                        Or this Keda 4074.................i own one and its a great motor, 4074 and 4 poles.
                        http://www.offshoreelectrics.com/pro...prod=keda-4074
                          • 9488
                          great call man!
                          even cheaper...
                          Horizons prices are much higher than what we really need to make this boat fast
                          • LarrysDrifter
                            Big Booty Daddy
                            • May 2010
                            • 3278
                            I see the Thunder Power motor is sensored. Will it run without a sensor wire, or does one need to use a car/truck esc with it? Darin, I know you've been boating for a lot longer than me, but ive never seen a sensored marine esc. What esc are you using?
                            • Jpope
                              • Feb 2011
                              • 30
                              what do you guys think about a Leopard 4082, 1550kv motor with a seaking 180esc?? i have that set up in my crashed spartan and was wondering if would work? My spartan would run mid 50's untill a darn gator came up at last minute. i paniced and turned into the bank instead of away from it. Florida go figure! anyway if it will what prop would you try first??
