1500 vs 1800 motor
  • roadrashracing
    • 1462
    1500 vs 1800 motor
    what one will give you more speed? I know the 1500 has more torque but what will that do for a boat?
  • JimClark
    • 5907
    1500 will Handel bigger props
    Billy Graham
    • roadrashracing
      • 1462
      I guess the best is just trial and error?
        • 8011
        The 1800 will give better speed on this boat. A large prop upsets many monos, promoting chine walk and handling problems. The 1800 will still spin a smaller but adequate sized prop faster. The 1500 will draw less amps if propped appropriately and extend run time.
        • roadrashracing
          • 1462
          I have a grim 40x53 would it work better with the 1500 I get less performance out of the 1800 vs stock.
            • 8011
            You'll be slower with that small, low pitch prop on a 1500 Kv motor. I believe that is smaller than the stock Impulse prop.
            I don't understand the last part of your sentence. The Impulse comes with an 1800 Kv motor as the stock motor.....
            • TheShaughnessy
              • 1431
              that prop with the 1500 kv on 6s, now you're talking some speed. Don't know about a 60 amp speedo though.
              • martin
                • 2887
                As Fluid has said that 40 x 53 is to small only 2.08" pitch, The stock prop is 2.51" pitch. Martin.
                • roadrashracing
                  • 1462
                  so that prop I should just get rid of?
