My Impulse 31 misfortune
The higher C rating did not cause the esc to fry, the size prop you used did. The higher the C rating the better when it comes to boating. The batteries only supply the amount of amps that the motor demands. Just because your batteries can put of more amps doesn't actually mean the extra amps are being used. The motor pulls the amps the esc recognizes the amp load and request that amount of amps from the batteries. Higher c rating didn't have anything to do with that. A x447 if a very LARGE prop especially on ul1 motor.
I think this thinking comes from the traxxas fan boys?
But I am looking forward to the run in this hull on that big Leopard....NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8sComment
You think your impulse had it hard, mine is like a timex watch. Takes a lickin but keeps on ticking. Was t-boned by another impulse, so missing a big chunk of the side ( patched up with hockey tape, but can still see fiberglass). Then I installed ul1 motor in it, got carried away at the pond and t-boned my pt 109 ( which my son was driving) at full speed. The whole front end of the impulse was lodged into the side of the pt109 about 8 inches deep. Pt109 is a write-off, but the impulse still works.
I think the impulse is indestructible. Awesome boat, almost as fun as my motley crew( when the motley crew is working)
I've also got the impulse 26 for my 4 yr old to run. Awesome boat for $160. The thing isn't super fast, but is as agile
As a tugboat, and a 2s lipo lasts a half hour with room to spare. great retrieval boatComment
I'm glad your having fun with that boat...lol
Yes I only cooked the original ESC and mostly because I wanted more speed. Never had much luck with RTR electronics, not even in offroad vehicles. Also due to lack of experience I picked up the prop. But I tell you she flys with that prop.
Typically people buy prop based on their electronics, I bought electronics based on my prop....lol
So my leopard 4074 and seaking 180 are on their way. cant wait to try them out.
So I finally got the new electronics. Leopard 4074 2200kv and Seaking 180 esc running on 4s1p. I will be trying the new setup this weekend. Going to try with the stock prop first then the x447. Before I do that, I just need to make sure I am not over-proping this beast. Any thoughts?
So I finally got the new electronics. Leopard 4074 2200kv and Seaking 180 esc running on 4s1p. I will be trying the new setup this weekend. Going to try with the stock prop first then the x447. Before I do that, I just need to make sure I am not over-proping this beast. Any thoughts?Comment
Yea your gonna need two 4s packs or you can use four 2s pack in a series/parallel combination (that gets crowded though). You def need a 4s2p setup though with that prop or things may get ugly.... prop down until get a 2p setup!Comment
never been a huge fan of running two batteries in parallel. Tried it before and cells discharge wacky but worth the try. So your saying the Gens Ace 200 amp constant discharge wont cut it?
What speeds were you getting in your setup?
btw, cool Utube channel :)Comment
Thanks for youtube comment!Comment
42x55 should work just fine on 4s1p. some puffing is related to how tight the shrink wrap is around the cells.Comment
