Drive dog pin snapped
  • Mtwinste
    • Jul 2011
    • 135
    Well I was all pumped about installing a new X445 prop and when I tightened the nut the drive dog pins snapped so no running for me.
    Is there a replacement pin available or should I buy an entirely new aftermarket flexshaft and drive dog?
  • LarrysDrifter
    Big Booty Daddy
    • May 2010
    • 3278
    Is this a drive dog with a roll pin? If so, just buy a new drive dog with a set screw and use that.
    • Mtwinste
      • Jul 2011
      • 135
      Do I need to notch flat the shaft so that the allen screw in the aftermarket drive dog has something to bite into? Seems it will slide on a round shaft
      • RTR Racer!
        • Aug 2011
        • 3
        I'd just buy a new shaft, the stock proboat one won't last long with that prop on it. Btw larry you spelled Neu wrong in your sig.
        • Mtwinste
          • Jul 2011
          • 135
          There's so many shafts on OSE. WHICH one should I get?
          • sailr
            • Nov 2007
            • 6927
            What size shaft was it that the pin snapped on? The Hughey shafts use the pins. The Octura shafts use a drive dog with setscrews and YES you should file a flat on the shaft for the drive dog setscrew. I prefer the Octura shafts but have to resort to Huey's when I need .187 long shafts.
            Mini Cat Racing USA
            www.minicatracingusa.com
            • ron1950
              • 3024
              The proboat stiletto uses prob the same pin in there's if u need the stock part
              • Steven Vaccaro
                • 8723
                Here I th dog
                http://www.offshoreelectrics.com/pro...rod=oct-oc6dmm
                I'll have the entire cable/shaft setup tuesday.
                Steven Vaccaro
                • Mtwinste
                  • Jul 2011
                  • 135
                  Ordered that today. Which drive u order?
