So after talking with proboat today they said the reason why i was having problems with the boat cutting out was due to the batteries i was using. Apparently 40c is to low of a discharge rate. they said i need to use 50C. So i went down to my lhs and bought some new lipos (thunderpower). With in 30 seconds of my run the boat took off by itself and crashed into a rock. TOTALLED. the boat sank as far as im concerned. I called proboat back and they said they cant send me out a new boat. Pretty ticked off right now. $400 for the boat plus $250 for lipos down the drain.
Impulse 31 totalled.......
Ouch that sucks!
Did you get the boat back or is it on the bottom with Davey Jones?42" Osprey, 32" Pursuit, 26" Bling Rocket (rescue), Blizzard Rigger, JAE 21FE rigger, Hobby King rigger (RIP)Comment
It beats me man. I think it was the esc and receiver. It wasn't the radio because i used the one from my geico and the same problem happened. no pics. the boat is gone it sank. from what i saw the boat basically exploded when it hit the rock. such a nice boat to.Comment
That kind of loss will make a guy re-think rc boats as a hobby. I know its more frustrating than land rc vehicles.Comment
Sorry hear what happen to your boat.
But if it was me i would have to go snorkeling this week for it.
Was it salt water or fresh water ?Comment
The 40c/50c story just doesnt make sense................that boat can run on 20c 5000 batts if a person wanted to, the batts would get a bit warm but it wouldnt make a difference in it going wild as aopposed to 40 or 50c. Why would they tell you it runs on 50c, cuz thats just plain false. It was a radio issue i'm bettin'.
Here are Proboats "specs" directly from their site:
Length: 31 in (787mm)
Beam: 9 in (229mm)
Motor Size: 1800Kv brushless water-cooled
Radio: Pro Boat 2.4GHz pistol grip transmitter/Spektrum MR200 receiver
Speed Control: 60-amp brushless water-cooled
Hull Material: Fiberglass composite
Prop Size: 1.6 in x 2.5 in
Hull Type: Fiberglass Deep-V
Battery: 2-7.2V Ni-MH sub-C or 7.4 Li-Po 20C+ (not included)
Kit/RTR: RTR
Drive System: Flex shaft/direct
Minimum Age Recommendation: 14 yearsNEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
