how would i run 2 4s packs on this boat and still be safe
  • v-spec
    Banned
    • Jun 2009
    • 940
    For the money Gens ace.
    • lenny
      • Sep 2010
      • 4294
      ? ONLY IF THEY WORK
        • 9488
        Originally posted by arp1500
        ok so you guys dont recomemend using the deans connectors
        why do they melt
        Deans can take 60amp cont. I think, where as Bullet connectors can take much more amps
        this is what I did to run deans on my SV27 boat running parallel packs
        I soldered the back leads of the connector and placed this on one side of the stock series wiring on the esc
        and these are my parallel connectors for bullet packs
        • arp1500
          • Jun 2011
          • 146
          brushless 55,
          looks good
          is it needed 2 run bullets because everything else i have is set up with deans 5 battery packs, 2 chargers, 4 trucks
          so how is the inside of th eproboats wired..
          would i have to cut off the stock deans and re wire that also or just make a adaptor
          • arp1500
            • Jun 2011
            • 146
            does anyone have a pic of the inside of the boats with the wires exposed
            • electric
              • May 2008
              • 1744
              Let me take shot at explaining the series/parallel thing. Forget connectors for just one moment and lets just talk wiring.
              1. Parallel. Take the red wire from battery one and connect it to the red wire coming out of battery 2 and then connect that to the red wire going to the esc. Repeat the same thing for the black side. Now you have two batteries connected parallel. Same voltage, but twice the MAH's.
              2. Series Now this looks weird, but I promise it will not blow up. Plug a red wire out of battery one, into the black wire of battery two. Now, take the red wire from battery one and hook it to the esc, and then take the black wire from the battery two to the esc. You have now doubled the voltage, but same MAH.
              With bullet connectors, one connector per wire comming out of the battery, here is how I hook it up series.
              1. Plug the red wire of battery one into the black wire of battery two.
              2. Plug the red wire of battery two into the esc.
              3. Plug the black wire of battery one into the esc.
              4. Ready to go.
              Might help you picture how it works better...
                • 9488
                not sure if these pictures will help, but here is a 4s2p setup using 4 2s packs
                • lenny
                  • Sep 2010
                  • 4294
                  Wiring diagrams in OSE tips & info,http://www.offshoreelectrics.com/inf...l-parallel.php
                  ? ONLY IF THEY WORK
