r 2 water pick ups necesary? or would i be fine with the one on the rudder and turn the tubing into a "Y" for the motor then esc? is the stock water cooling ok?
Stability Problem Quastion....
Mind you that 2 of them are even better to keep temps down but Fastech and BJ stock setup is running very cool on one line so no worries. When it comes to Y for cooling it is not my best idea becouse water will allways go the easier way so it wont be devided equally.
RobertDJI Drone Advanced Pilot
CanadaComment
... trims down will make boat run wet, yes nose down but will decrease speed and it may increase load on your esc and motor wich means you may gain a little on your temps, make sure to check temps often.... You need to find the perfect balance....DJI Drone Advanced Pilot
CanadaComment
It will but will also slow down and worm up a liitle higher. You need to play arround with it. Find the perfect balance between plane and in the water for the optimal performance that you will like the most...DJI Drone Advanced Pilot
CanadaComment
