I'm having issues with my fastech when running my boat I can barely see any water coming out of the outlet. My other boats I can clearly see a stream I'vechecked all the hoses and even connected it to my modified jet boat and tried to force water through the outlet I see no leaks but still only a small amount of water is coming out. Can someone please give me some other things to check or tell me if my boat is ok?
Water outlet
Go to your local pharmacy and pick up an oral syringe. They are freebies here in Ontario. Remove the tubing from your water pick up and fit the loaded syringe into the free end of the tubing. Force the water through the cooling system using the syringe and see if it flows freely through to the discharge. That will at least confirm sufficient flow through the system. I have sv27's and usualy only see about a 2 inch stream of water coming out the discharge.A dream not pursued is not worth holding.
Aquacraft SV27 x 4, Proboat Mini-V, Redtail Kneeler Hydro, JAE21, ML GP335 -
to test this, isolate each variable, until you find the culprit. you could run a cleaner through your cooling system, this should be done periodically. be careful with corrosive prosucts because they can ruin the tubing and cause further leaksComment
OK I used the oral syringe and it gets a good flow with no noticable leaks, however whenever I run my boat I still can't see an real waterflow coming out the system. Honestly I have a better stream of water coming out of my girlfriends stock mini rio.Comment
Did you check your rudder? Sometimes small debris get stuck in the water pick-up holes. My plastic syinge has a bend narrow tip which allows me to directly shoot water into the holes with pressure, that way I get to make sure water is coming out even if it is slightly blocked, the presure will hopefully force whatever that's in it out. Disconnect the silicone tube from the rudder when doing this.Too many boats, not enough time...
Actually it is better and simpler to disconnect the silicone tubing and shoot the water from the top of the rudder water nipple ( reverse flushing the rudder, if you will) and this way you can seat the syringe better and creat a higher water pressure.Last edited by tlandauer; 07-31-2011, 02:37 AM.Too many boats, not enough time...
Well its still not working right. I looked closely into the water inlet in the rudder and to me it looks as if theres a piece of metal that just seems out of place. I was wondering if I should try to take a drillbit or a small file in there possibly. Thanks for your advice.Comment
Well, it is worth a try, you never know if the machining process was all complete. However, my personal experience is that the amount of water that is picked up is not always even : on some of my boats there will be more water when I steer the boat on one particular direction. Meaning when the boat leans to a particular side. You need to see if that's the case. I haven't figured out why that is. I thought it depended on which side the hole on the rudder. When you turn and the boat is leaning on the side of the hole there is usually more water, so i thought may be the depth has something to do with it. Hopefully someone else with more knowelege can tell you more.
Also, I know you tried to blow eveything and I assume water was coming out, that is under more pressure than the boat 's own pressure when travalling, did you check if the silicone tubing is pinched or are there by chance small turns any where inside the boat, give another inspection.Too many boats, not enough time...
Check your temps on esc and motor after 3 min runs, And water temp where you are.Comment
Well, my Fast-Tech after 3 yrs. of sittting in the garage I tried to run it today, guess what?! Can't see the water flowing out! Only when in certain positions could the water be seen. I think it is an optical thing, the blue/white color of the boat makes the water hard to see. I know the boat's motor/ESC is getting enough water because it is barely warm. Of much more serious problem and the reason I was not thrilled with the boat is that it is letting in water. I checked everything and finally I took the radio box off and saw what is happening: in static water, the stuffing box ( tube) is letting water in just below the motor collet, I held the boat in water and can see the drips! I placed a silicone tube around the flex and tube , will try tomorrow and see what happens, now I remember 3 years ago was the same problem and I wasn't reading these forum and didn't know what to do.Too many boats, not enough time...
? ONLY IF THEY WORK
