Flexdrive cable adjustment
  • Deserthobbies
    • 50
    #31
    Originally posted by shotimes95
    would 5000 mah 50c be overkill?
    my 40C's dont even get warm. and thats running it hard down a 1/4 mile pond
    • shotimes95
      • 101
      #32
      thats good. what would the 20c's do? would the electronics be strained or the batteries? proboat told me that theres not a noticable difference between the 20c and 25c. cause i can only afford to buy 1 set of 50c's and i have 2 sets of lipower 7.4v 20c, 30 burst. What would you do? you know more than i do
      • Deserthobbies
        • 50
        #33
        you will probably be ok, just watch your temps on the wires and batterys , lipos wont strain as bad as NIMH batterys do. I have some good quality NIMH and they get hot as hell before they are run down half way. my 40 C lipos are the same temp after running hard as they were when i put them in the boat.
        • shotimes95
          • 101
          #34
          on the battery wires or the esc wires? and also could i use 2 3s 11.1v lipos? i wanna run it hard but not ruin it. other threads say it can handle a total of 6s but im not sure. Thanks for being so understanding... im asking all the questions LOL
          • Deserthobbies
            • 50
            #35
            The motor is rated for 6 cells but not the ESC, The esc is only rated for 21 volts.
            • shotimes95
              • 101
              #36
              Just picked up 2 orion carbon 45c 5400mah lipos... now just need a x642
              • forescott
                Hopelessly Addicted to RC
                • 2686
                #37
                Hey shotimes, I think 50c is way overkill. 40c is probably too. 25-30c burst rate is perfect. Anything more wont gain any more performance. It will just drain the packs quicker. 40-50c packs are used more for larger can motors that require a lot more juice.
                • forescott
                  • 2686
                  #38
                  Hey Desert, have you thought about using jb weld epoxy for that flexshaft?? I'm pretty sure thats how most of the flex cable/prop shafts are joined nowadays.
                    • 7990
                    #39
                    Most commercial cables are still soldered/brazed. I'd definately not trust JB, that function is not what it is designed for and its viscosity precludes the tightest joint fit. Permatex sleeve retaining compound has a great history of success, even in SAW boats.
                    • shotimes95
                      • 101
                      #40
                      I figured it may be but i can use them in other vehicles of mine. I couldnt pass up the price for the orion packs! The packs i have are 30c burst and the stock props keep exploding once the boat comes out of the water and back in... Im not sure why but thats why its a hobby lol
                      • forescott
                        • 2686
                        #41
                        Thanks for the info fluid, I learn something new everyday!
                        • forescott
                          • 2686
                          #42
                          By exploding do you mean cavitating? Spinning free and then grabbing again.
                          • shotimes95
                            • 101
                            #43
                            the prop breaks apart and only the center is left on the shaft by the retaining nut afterwards..
                            • Deserthobbies
                              • 50
                              #44
                              that will hapen to the stock props they rev when they leave the water and when they come back in contact with the water its like hitting a brick.
                              • Deserthobbies
                                • 50
                                #45
                                no way JB weld will hold , ill silver solder it or braze it with a brass rod.
