Can I use the interneal BEC with 4S lipos?
  • BHChieftain
    Fast Electric Addict
    • 1969
    Hi,
    Just converted my fastech to lipos (4S). Can I still use the internal BEC from the ESC or do I need to run a pack or UBEC to the receiver/servo?
    Chief
  • Jesse J
    scale FE racer
    • Aug 2008
    • 7128
    Yes, the stock ESC is rated and 4S ready. you only need to run external bec if you go higher than 4S.
    "Look good doin' it"
    See the fleet
    • BHChieftain
      • 1969
      Thanks sir! Just saved me from cutting a wire...
      Funny how this little 45A ESC can handle 4S, but the castle creation 240A can only handle 3S!
      Chief
      • Jesse J
        scale FE racer
        • Aug 2008
        • 7128
        they say it is way under rated. I don't mean to suggest anything, but I have run it on 6S with internal BEC and had no problem... in my twin cat going nearly 60mph. BUT I have also fried several of them on 6S w/internal BEC in monos... stinky. If you want to go higher voltage, you must either turn down timing, or use external BEC. And you don't need to cut - you can remove wire from plug or get a 6" extender and cut the wire in that.
        Not sure which CC ESC you mean, I thought they were 6S rated...
        See the fleet
        • BHChieftain
          • 1969
          The Hydra 240A (standard model) is only 3S rated on the BEC-- it is in the manual and there was also a thread on it.
          Chief
