FASTech Steerable Outdrive
  • airman66285
    • Aug 2009
    • 244
    I was not satisfied with the offset rudder system so I changed it over to a steerable outdrive. The control and handling is much, much better. This is my sport boat so I use it to tool around between 35 and 40 mph with Zippy Flightmax 2S LiPo's. This is a very fun boat to drive - quick, stable and forgiving. I altered the turn fins and trim pads based on the information from this site and it does help incredibly! The prop I am using with this setup is an Octura X642 B/S. The radio is a Tactic 2.4GHz but everything else is stock.
  • LiPo Power
    DJI Drone Advanced Pilot
    • May 2009
    • 3186
    Great idea and great looking boat....
    Canada
    • blackcat26
      High Speed Junkie
      • Sep 2009
      • 1598
      Looks like you are using a regular flex cable and no pesky U-joint is that correct?
      FE BOATING: Less like a hobby and more like an addiction!
      • BHChieftain
        Fast Electric Addict
        • 1964
        Glad you made this work.
        Note, I personally really like the fixed drive/offset rudder config on the fastech. It does require matching speed and rudder input to turn the best, and I like the little bit of challenge.
        -Chief
        • airman66285
          • Aug 2009
          • 244
          You are correct - I am using a .150 dia. flex cable instead of the inferior stock universal joint. I forgot to mention that I had to use a HiTec high torque servo in order for the set up to work best.
          • blackcat26
            High Speed Junkie
            • Sep 2009
            • 1598
            That's not a bad idea! I had thought of something like that but decided to ditch the steerable system all together on my BlackJack. Those u-joints do suck! Nice job!
            • Visual Perfection
              • May 2010
              • 312
              Any videos of it in action?
              The Speeders *PB SW 26 BL *PB Formula FASTech
              The Cruiser *CBM Marlin Cruiser
              The Pool Toys *Proboat Mini-C (x2)
