Proboat Shockwave 26 motor Aluminum mount
  • CalvinVllaun
    • Oct 2022
    • 5
    Does anyone know of an Aluminum Motormount available to replace the original plastic mount that would space the motor further away from the stuffing tube mount to allow a longer coupler. I'm converting to a pianowire flex drive and need some extra room and to stiffen up the flex from the factory mount. Also anyone know of a coupler 5mm motor to 2mm .078" that is aproximately 25 mm long. The one in the picture is way too big and the shortest Octura one is 32 mm long.
    Thanks
    Cal
  • koen
    • Mar 2020
    • 361
    TFL has a big choice of motor mounts, OSE sells them they have also the coupler
    • CalvinVllaun
      • Oct 2022
      • 5
      Motor mount for Shockwave 26
      Thanks Koen
      I could not find a mount that was bolt in so i got the Dremel out and Fabricated one allowing the space neede to use the longer coupler
      The Octura coupler that Steve from OSE recommended worked with the 5mm motor shaft and 2mm wire drive.
      • koen
        • Mar 2020
        • 361
        looks good and strong
        • fweasel
          master of some
          • Jul 2016
          • 4291
          Kintec used to sell an upgraded motor mount for this application. Guess what, it looked exactly like the one you just made yourself. Nice work.
          Vac-U-Tug Jr (13mph)
          • CalvinVllaun
            • Oct 2022
            • 5
            Thanks fweasel. I saw a post with Kintec's mount and i was trying o find one. I don't know if they are still in business. Fortunately the Factory mount is at a 90? angle so made it from an piece of Aluminum 90? Angle "iron". The tough part was getting the mounting holes right especially to align it properly for a wire drive. Someone with a CAD program could easily design and sell it as an upgrade.
            • fweasel
              master of some
              • Jul 2016
              • 4291
              Sadly, the owner of Kintec passed away a number of years ago and they're no longer in business. I had one of their mounts in my Shockwave and was going to suggest you make your own before I read the rest of the replies and saw that you beat me to the idea.
