New Pro Boat Impulse 32" Brushless Deep-V RTR
  • jhurlbert
    • May 2019
    • 74
    Anyone notice this boat has the same prop as the blackjack 42 but the finish on the one it comes with sucks. The one on my bj 42 has a polished finish and the replacements are polished too
    • jhurlbert
      • May 2019
      • 74
      Some toyota form in place gasket behind the nuts on the spots that were leaking water and shes all water tight now. Unlike epoxy i can take it apart easily if need be.
      • alvinm
        • Feb 2012
        • 77
        How did you guys do the water test? I placed the entire boat in the water and then pushed down until the water level was almost to the hatch. Should I just stick the back end into the water? Also, did the water gush in because, the amount of water I'm getting after just a couple of passes to me seams too excessive to be a minor leak through some bolts.
        • jhurlbert
          • May 2019
          • 74
          I did the same as you, in my pool. I had water after about 10 sec
          • alvinm
            • Feb 2012
            • 77
            I did notice they looked very similar but assumed they were different because of differences in power.
            • alvinm
              • Feb 2012
              • 77
              Okay, so I'm about to send this boat back, but I have only one thing left to check. I noticed some bubbles coming through the motor water jacket when I blew through the hose. I'm gonna take it off, maybe it's missing o-rings or something.
              • alvinm
                • Feb 2012
                • 77
                Success!!!!! I immediately noticed the rather thin o ring didn't have a great seal on the motor. I applied a thin bead of silicone around the edge of the water jacket and clamped down hard on the plastic mount that goes across the top. Now it's bone dry! What a relief.
                • jhurlbert
                  • May 2019
                  • 74
                  #23
                  My cooling jacket is leaking too.
                  This boat so far is a hand-full. All i have done so far is a slight strut down adjustment. I have run both 2 3s 4500mah batteries and 2 6000mah batteries. Likes to bounce. Seems more so with the 6000mah batteries. I think this boat has more than enough power. Next is to make a bigger strut dow adjustment and see how she rides
                  • alvinm
                    • Feb 2012
                    • 77
                    #24
                    I wanna say my strut came from factory all the way down. I may be wrong but it's currently at the least position. I also lowered the trim tabs down about an 1/8th. I'm not getting much bouncing. I haven't had a chance with the wind and chop to get nice long passes but I still got it to 52.
                    • alvinm
                      • Feb 2012
                      • 77
                      #25
                      The batteries are all the way forward touching the cross brace.
                      • jhurlbert
                        • May 2019
                        • 74
                        #26
                        About 5 runs i i noticed this
                        • alvinm
                          • Feb 2012
                          • 77
                          #27
                          What's the issue?
                          • jhurlbert
                            • May 2019
                            • 74
                            #28
                            The big crack up by the drive dog. I dont know if it came that way or just happened
                            • jhurlbert
                              • May 2019
                              • 74
                              #29
                              I have contacted horizon about the leaking cooling jacket and cracked prop. We will see what they say
                              • alvinm
                                • Feb 2012
                                • 77
                                #30
                                Yeah I wouldn't run it until it's replaced. I think the BJ 42 has the same or similar prop, in case you have a local hobby shop that has those in stock.
