OK, this is the cool idea I had...
To solve the issue of HOW to seal around the stack, my solution was to make the stack MOVABLE...
SOOOOO... I got an aircraft aileron hinge, and mouted the back of the stack to the transom with the hinge.
I marked the stack so that I could trim it to JUST touch the cowling, then sanded it down to fit.
I used one of the magnets for the factory hatch and embedded it into the front original stack mounting hole. I used a 3/8" wood hole bit to drill down. There is a piece of foam or wood or ??? under the deck in the back, so if you are VERY careful, you can slowly drill it down to a depth where the magnet side of the latch is JUST below the deck.
ON the stack, I modified the front mounting hole to accept the other halve of the magnetic latch, and epoxied it into place.
