Miss Geico 36 twin strut adjustment
  • Fixitguy1
    • Nov 2016
    • 45
    I m using Giant Power 6000 70c-140 x4 batteries and Daboata 1815 props
    The stock setting is 2.5mm wondering where I should be at with this set up
  • dasboata
    • Dec 2010
    • 3152
    Is that 2.5 up or down,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, angle I presume ???????????????????
    • Fixitguy1
      • Nov 2016
      • 45
      That’s 2.5mm down for the stock setting
      One respond was push batteries all the way up, drop the strut all the way down and hang on
      • MADRCER
        • Feb 2017
        • 751
        That?s 2.5mm down for the stock setting
        Sounds like someone is trying to give you a setup to run on the Gulf of Mexico....The stock setting with batteries in the normal position sounds pretty good to me, if I was running on flat to semi flat water.
        • Fixitguy1
          • Nov 2016
          • 45
          Yeah I think that guy showed a picture of that boat after it flipped back over front and cart wheeled
          I’m going to run it with the stock props and stock setting first to see what I have
          Thanks
